Thread: Turbo: better on a l67 or l36
Results 1 to 9 of 9
  1. #1 Turbo: better on a l67 or l36
    GTX Level Member colindunn's Avatar
    Aurora, IL
    Looking into a project over the summer. Do turbos make more power on an l36 or an l67 with a supercharger block off plate? Or does it not make a huge difference?
    on a side note is a 1997 bonneville as "bad" as buying a 1997 Grand Prix? Or is it fine because it was redesigned before that year and doesn't have the issues the '97 gtp's do.
    I KNOW the l36 engine doesn't have an HD trans but that does not matter.
    Green Comp G. Headers. Intake. Tune. Pulley. Intercooled.
    SE fascia. Dual chrome tips. Debadge. Retrofit. Lowered.
  2. #2 Re: Turbo: better on a l67 or l36
    will do well on both. you'll be able to run more boost on an L67.
    not sure about the bonne, but it might have the 4t65e already in it (which would be good).
    the 4t65e takes just as much abuse as the 4t65e-hd.
  3. #3 Re: Turbo: better on a l67 or l36
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    a 97 bonne will have a 4t60e in it if it is N/A.
    a 97 SSEi (supercharged bonne) will have a4t65e-hd
    97 Bonneville SE Not so much a 97 anymore
  4. #4 Re: Turbo: better on a l67 or l36
    Aurora, IL
    Yeah and in '98 the 4t65e was used with the n/a bonne.
    I just thought I could make more power with less boost on the n/a motor since that intake manifold flows better than a blocked off suoercharger.
  5. #5 Re: Turbo: better on a l67 or l36
    Jan 1970
    Maquoketa, Iowa
    I don't think you would notice a big difference until 500+whp.
  6. #6 Re: Turbo: better on a l67 or l36
    new britain, ct
    lower compression=more boost, more boost is *usually* better on a turbo setup.
    07 Black GXP.
  7. #7 Re: Turbo: better on a l67 or l36
    May 2008
    Schuyler, NE
    You'll make more power with the L67, as long as you have a properly sized turbo.
  8. #8 Re: Turbo: better on a l67 or l36
    Feb 2009
    flintnasty MI
    nah, I always made better power on the L36's. Lighter rods, lighter pistons, more compression was always nice. The only problem is that pesky rod exploding issue they have passed 500whp.
    Intake manifold you use has little to no effect on power.. you can swap a L36 intake onto a L67 motor for less than 20 bucks I bet.
  9. #9 Re: Turbo: better on a l67 or l36
    May 2008
    Schuyler, NE
    In my experience, the L67 makes more power than the L36.
  1. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
