Thread: Ignition Module Dilemna
Results 1 to 7 of 7
  1. #1 Re: Ignition Module Dilemna
    St. Louis
    I would give your coils a check and see if any of them are visibly cracked/arching. Fire it up and mist them with some water and see if you notice any spark jumping where it shouldn't be. Best to do this in the dark so you can see the arc better (if there is any). I had a coil crack on my 00 GT and shortly thereafter toasted my ICM. Replaced that coil and the ICM and it's been fine ever since. The coil was cracked on the side near one of the towers. Hard to see when it was dirty and as I was cleaning them off to install my new ICM I happened to notice it.
  2. #2 Re: Ignition Module Dilemna
    Mar 2013
    United States
    will do
  1. ignition control module EMERGANCEY
    By Myers1985 in forum General Tech Discussion
    Last Post: 12-12-2016, 02:00 PM
  2. HELP! Ignition Switch: Removing Passkey Module
    By Lawngoose in forum General Tech Discussion
    Last Post: 06-20-2009, 05:44 PM
  3. Possible Ignition control module problems?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 05:04 PM
