Thread: Ignition Module Dilemna
Results 1 to 7 of 7
  1. #1 Ignition Module Dilemna
    Mar 2013
    United States
    2004 Grand Prix GT - Ignition modules last 3 months. Changed out 5 times already.
    Car just will not start. Cranks but no fire. Replace module and on the road again for 3 months. Repeat.
    Tested all circuits leading to plug of ignition module and all external sensors are working. Crank sensor replaced 2 times, but nothing wrong with them. Grounds seem to be ok.
  2. #2 Re: Ignition Module Dilemna
    Ohio
    what brand are you buying?
  3. #3 Re: Ignition Module Dilemna
    St. Louis
    I would give your coils a check and see if any of them are visibly cracked/arching. Fire it up and mist them with some water and see if you notice any spark jumping where it shouldn't be. Best to do this in the dark so you can see the arc better (if there is any). I had a coil crack on my 00 GT and shortly thereafter toasted my ICM. Replaced that coil and the ICM and it's been fine ever since. The coil was cracked on the side near one of the towers. Hard to see when it was dirty and as I was cleaning them off to install my new ICM I happened to notice it.
  4. #4 Re: Ignition Module Dilemna
    Mar 2013
    United States
    Quote Originally Posted by MoarkatsINmuhtrailer View Post
    2 different brands/ non-gm
  5. #5 Re: Ignition Module Dilemna
    Mar 2013
    United States
    will do
  6. #6 Re: Ignition Module Dilemna
    There is a ground that GM added to the harness in the mid 90's due to high failures based off bad ground. If you look at the end of the head, there should be a black ground right there. Ensure it's hooked and getting a good ground.
  7. #7 Re: Ignition Module Dilemna
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    ^ I second what bill said.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. ignition control module EMERGANCEY
    By Myers1985 in forum General Tech Discussion
    Last Post: 12-12-2016, 02:00 PM
  2. HELP! Ignition Switch: Removing Passkey Module
    By Lawngoose in forum General Tech Discussion
    Last Post: 06-20-2009, 05:44 PM
  3. Possible Ignition control module problems?
    By DWosik13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 05:04 PM
