Thread: annoying thumping sound at firewall idling in gear
Results 1 to 18 of 18
  1. #1 Re: annoying thumping sound at firewall idling in gear
    St. Louis
    Sounds like where the DP bolts to the rear manifold. Maybe try tightening the 2 bolts up and see if it fixes the rattle.
  2. #2 Re: annoying thumping sound at firewall idling in gear
    SE Level Member teejay's Avatar
    Feb 2013
    ohio
    Yes, it is where the DP bolts to the rear manifold and they are tight and nothing leaks.I think I know what is making the DP rattle, the engine vibrates at an idle just enough to make the inside of the car rubble and make the plastic rattle.It's not a miss, I dont think, it runs perfect otherwise.With my foot on the brake and the other on the throttle it never really stops vibrating till around 1100 rpms and then it slowly smooths out. I have sprayed the entire top of the engine with carb cleaner to see if it has a vacuum leak but have not found anything.The plugs and wires are all new.I cant think of what else would cause a vibration like that. Could there be a vacuum leak elsewhere or do you think its something else?
    02,160,000 miles, was silver, painted it black after tornado totaled it,that did'nt take much. American Racing wheels,aluminum grills,Stinger Fiberglass hood,drivetrain stock.
  1. Strange pulsing/thumping sound no one can figure out...
    By SliceTheRice in forum General Tech Discussion
    Last Post: 01-31-2013, 09:52 PM
  2. Clicking Coming From R&P Area & Rapid Thumping Sound While Driving
    Last Post: 10-08-2012, 01:28 PM
  3. HELP! Hissing sound after drilling though firewall
    By Jomamma in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2012, 11:26 PM
  4. Thumping noise when braking
    By 400exHauler in forum General Tech Discussion
    Last Post: 10-11-2010, 12:46 AM
  5. Light Thumping sound under car :S
    By 9ordohz in forum General Tech Discussion
    Last Post: 02-18-2010, 12:47 PM
