stock pump, but would add the rewire kit to boost voltage.
no tuning required for anything under 125. just be SMART. 75 dry will work fine, just make sure you spray it BEFORE the MAF.. Wet kits spray in fuel too, so you would want to spray it after the MAF.
The Wet kit ties directly into the schrader valve in the front of the fuel rail to get its supply of fuel. any valve core remover from tires will work to remove this.
just dont get overlly excited. have it set on a WOT switch. or f you trust yourself enough....a pushbutton. just let the button go BEFORE you pll your foot off WOT....things can go KaBOOM!
other than that, enjoy!
