Thread: Need help with a couple issues
Results 1 to 2 of 2
  1. #1 Need help with a couple issues
    SE Level Member wingman65's Avatar
    Dec 2010
    Missouri
    Just finished swapping out motors in my 95 Grand Prix after cam breaking in half and now I have a couple problems. The car will not shift automatically and no speedometer. Car acts like it is in 2nd or third gear and check engine light is on. Other problem is that my cooling fans are not coming on and temp rises way too high. Any ideas as to what to look for is appreciated.
    I put an engine (3100) in this car 2 years ago due to same problem, cam broke due to LIM not caught in time, I guess the motor I bought had the same problem though it looked good and clean and I put the metal Felpro gaskets in before putting in car yet here we go again. This motor has 74,xxx miles, clean inside and original gasket just starting to fail so maybe this one will be saved.
  2. #2 Re: Need help with a couple issues
    Ensure the cooling system is bled.
    Check the differential end of the trans. There is a sensor VSS that should be hooked up there. That is how your car knows what speed it is going.
  1. Couple of issues with my 01 GT I just purchased.
    By gold01gt in forum General Tech Discussion
    Last Post: 02-20-2012, 07:05 AM
  2. having a couple issues
    By gtcoup in forum General Tech Discussion
    Last Post: 03-05-2011, 11:59 PM
  3. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  4. Couple of issues I need to diagnose
    By FlaminWhite97GTP in forum General Tech Discussion
    Last Post: 12-02-2009, 11:20 PM
  5. Couple Issues
    By BwolfGT in forum General Tech Discussion
    Last Post: 07-29-2009, 09:45 PM
