Thread: Blower motor resistor, Coolant leak?
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    I know the rtv wouldnt help. Thats if everything is well.
    Would it be a hard install?
    Thanks for all your help btw, I really appreciate it.
  2. #22 Re: Blower motor resistor, Coolant leak?
    A timing cover?
    It's not horrible. You drop the ps pump down (2 x 13mm) Then pull the harmonic balancer, (already have coolant drained)... A few 13mm bolts and it's off. Wiggle it out and switch, new timing cover gasket is cheap.
    Thinking aloud here, it's probably an hour or two job for most guys.
  3. #23 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    Well, Ill let you know in a few hours if I need one.
    Thanks a lot!
  4. #24 Re: Blower motor resistor, Coolant leak?
    I hope you don't, but fear it's the mysterious leak. Especially after you said 97/98.
  5. #25 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    PHEW!... no cracks!
    Okay so I did the whole process again, for the third time now. Lightly sanded the holes clean, made sure everything was clean. Put rtv under the o-ring and behind it. Im still not confident it sealed. Its only been a little while since I got it done, I noticed liquid splashing off the belts but nothing dripping down under the car.
    ...we'll see.
  6. #26 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    I drove it around some more and I'm pretty sure it's all sealed up. No more leaky
    My car decided that it wasn't broken enought anymore so abs lights on now, and my remote start starts up, runs, then shuts off and restarts.
  7. #27 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    Shortly after I remembered I forgot to put the plug back into the alternator. That fixed the abs and the remote start issue
    Pretty sure its still leaking a tiny amount. -_-
  8. #28 Re: Blower motor resistor, Coolant leak?
    hows the water pump? grab the pulley, engine off, belts still on with 2 hands, push with one, pull with the other back and fourth, if theres play the pump could be leaking, they will leak off and on, at will. and leak/drip strait down to the balancer and motor mount.
  9. #29 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    Thanks man,
    Ill check it tomorrow.
  10. #30 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    No play in the water pump pulley.
    I'm beginning to think that the leak isn't coming from the lower cast elbow. All signs point to that, but I cant actually SEE if its leaking from there and I've re-sealed it three times now.
  11. #31 Re: Blower motor resistor, Coolant leak?
    you can slide your fingers in to the elbow to see if its dry. mirrors and a flash light also works to see better.
  12. #32 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    Couldn't figure out what the hell it was. So I took it to a mechanic friend so he could pressure test it and what not.
    Its the water pump
  13. #33 Re: Blower motor resistor, Coolant leak?
    Doooh
  14. #34 Re: Blower motor resistor, Coolant leak?
    Howell, NJ
    293 some friend huh? Haha
  15. #35 Re: Blower motor resistor, Coolant leak?
    wow, water pump costs 40 bucks. comes with a gasket.
  1. blower motor resistor?
    By 04silverprix in forum General Grand Prix Discussion
    Last Post: 01-08-2013, 12:02 PM
  2. POOR BLOWER MOTOR AIR FLOW (resistor and blower motor already replaced)
    By jsmit162 in forum Introductions/Noob Questions
    Last Post: 11-06-2012, 10:22 PM
  3. The Old and The New, Blower Motor Resistor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 01-29-2008, 12:31 PM
