Thread: Really.... laggin, now over heating, and tach reading 20 mph higher than actual speed
Results 1 to 9 of 9
  1. #1 Really.... laggin, now over heating, and tach reading 20 mph higher than actual speed
    SE Level Member DaniGirl's Avatar
    Mar 2013
    Naples, FL
    New to the grand prix family, always been a bit fascinated with the cars. So I just picked up a 2008 very clean, and drove great for the 4 hours we were test driving....then we go home
    I suddenly get a 'Reduced Engine Power' car begins to lag, doesn't want to pick up, very slow on reaction. This happens occassionaly not a constant problem; but I'm sure if I don't correct the issue it will become a bigger problem (problem #1)
    Husband takes it to get the code, comes back with an explanation and no code so I am going today to get the codes (problem #2)
    Driving to work today, much better no lag....then I notice I'm driving slower than everyone around me in a 55 MPH zone, and the car is telling me it's going 85 MPH; get to my office and park....car states it's going 20 MPH while in park. - restart the car, needle gets stuck at 80 MPH while in park, restarted again, no change... waited a minute, restarted, finally read correctly. (problem #3)
    over heating, not majorly bad but always a concern, noticed yesterday after driving 80 miles while in stop and go traffic, I arrive home, open my gate and get in the car, and the needle has gone up; pull into the drive wait to see if it climbs, slightly climbs and then slowly start to go back down (problem #4)
    With the exception of #2, I'm not sure if they could all be related or seperate, or any ideas from any one on what I'm looking at here...
  2. #2 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    St. Louis
    Welcome to the forums!
    These cars run hot even on a good day. How hot are we talking here (on the gauge)?
    Check the battery connections for corrosion and tightness. Might want to pop them off and clean them up real good then tighten. I've seen loose/corodded cables do strange electrical things to these cars.
    And definetly grab the codes.
  3. #3 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    Mar 2013
    Naples, FL
    Here's the codes:
    P0030 2x heater control circuit bank 1 sensor 1
    P0036 2x heater control circuit bank 1 sensor 2
    P0053 2x heater resistance bank 1 sensor 1
    P0054 2x heater resistance bank 1 sensor 2
    P0134 02 sensor circuit no activity detected bank 1 sensor 1
    P0405 2x exhaust gas recirculation sensor a circuit low
    P1125 throttle position sensor intermittent
    P2120 throttle/pedal position sensor/ switch d circuit
    P2138 accelerator pedal position sensor 1-2 correlation
  4. #4 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    Mar 2013
    Naples, FL
    Transmission temp was about 200 heard they run about the same
  5. #5 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    St. Louis
    Well, the temp sounds about right.
    That is a list of codes, lol... Off hand the TPS looks like it may be suspect, along with the front O2 sensor. Being an 08 it may be a good idea to remove the entire throttle body and all the sensors and then clean it until it shines, then clean the MAF w/ approved MAF cleaner spray and then see what you get. The TB's get gunked up on the DBW systems and cause all kinds of wierd issues. Best of all it's the cheapest thing you can start with w/o replacing parts.
    The rest I'm not sure on. Maybe try a quick search for those other codes and see what comes up in other threads.
  6. #6 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    Honestly..I'd check fuses first. Looks like all the circuits that are tied together.
  7. #7 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    Mar 2013
    Naples, FL
    Checked fuses found only 2 bad, no difference, chsnging out the 02 sensors and the tbp....just a note, when I get the engine power loss (once a week) I lose cruise control and mph is way off. Hsve to retart car 2 x times for every thing to go back to normal.
  8. #8 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    GT Level Member Shiftingshaddow's Avatar
    KC
    i'm just guessing you have either 1 big problem or several little problems. my first guess was your cluster but as i read more you have real engine codes.
    maybe check your vacuum hoses. when you have the loss of power and the cruise not working it may be a vacuum issue. those vacuums cause a lot of fits.
    maybe a bad pcm? its the car's computer. this isn't as bad as it sounds. they are easy to change.
    sounds to me like an electrical issue somewhere, though.
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  9. #9 Re: Really.... laggin, now over heating, and tach reading 20 mph higher than actual s
    Donating Users
    Sep 2012
    LI, NY
    I don’t know if this helps.
    Is 'Reduced Engine Power' the same as "Limp Mode"??
    I don't know if the '08 GP transmissions have a Transmission Control Module(TCM) or "Input/Output Sensors" also called "Speed Sensors(not the ABS Speed Sensors)".
    My '00 Dodge Intrepid had them.
    When the input sensor goes bad, the car will only drive in 2nd gear("Limp Mode").
    When the output sensor goes, the speedometer will not work.
    I tried doing a search for a TCM and I/O Sensors for an ’08 GP.
    The only thing that came back were speed sensors for ABS.
  1. FIRST ACTUAL UPGRADE! lol
    By clevelandfan in forum Visual/Body Modifications
    Last Post: 03-07-2010, 09:57 PM
  2. Actual Timing > Spark Table
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 10-09-2009, 06:49 AM
  3. Replies: 9
    Last Post: 10-03-2008, 12:12 PM
