Keep this short and simple. Here in the spring I will be taking off my 105's and putting on 130's so I can turn up the boost more on the turbo without having valve float. While I'm swaping out to the 130's I'll also be adding Manley Ti Retainers.
My question is....Can Intense lightweight pushrods be used with the 130's spring setup?
Quote from Intense-Racing
"Our Lightweight pushrods (PRL Series) weigh 425 grams per set of twelve (approximately 25% less than the factory rods) and their .049" thick 4130 seamless chrome moly one-piece design is significantly stronger than stock. These are the ideal choice if you're running non-roller rocker arms in your naturally aspirated engine with stock, 90#, or 105# valve springs."
My thing is that they are supposed to be stronger and stock pushrods.....and many people run stock pushrods with 130's springs. So with having said that, shouldn't the lightweight pushrod work with the 130's??
