Thread: Is this safe to replace with ( fuel lines)
Results 1 to 9 of 9
BlackGT97 Is this safe to replace with... 02-19-2013, 04:18 PM
asite57 Re: Is this safe to replace... 02-19-2013, 04:25 PM
dsmuts Re: Is this safe to replace... 02-19-2013, 07:27 PM
Seachicken Re: Is this safe to replace... 02-19-2013, 10:03 PM
WolvesSoulZ Re: Is this safe to replace... 02-19-2013, 10:05 PM
TexasTanker19kilo20 Re: Is this safe to replace... 02-19-2013, 11:07 PM
BillBoost37 Re: Is this safe to replace... 02-20-2013, 06:46 AM
BlackGT97 Re: Is this safe to replace... 02-20-2013, 10:55 AM
BillBoost37 Re: Is this safe to replace... 02-20-2013, 11:16 AM
  1. #1 Is this safe to replace with ( fuel lines)
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    Just topped swap and i was wanting to replace my lines where the flex line meets the steel lines. I was thinking of replacing it with rubber hose up to the fuel rail and double clamping everything...Has anyone had a problem with this causing fires or something?
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  2. #2 Re: Is this safe to replace with ( fuel lines)
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Never did that on a 3800 but most of a mustangs fuel lines we just built are rubber, a good portion on mine are rubber underneath my car
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  3. #3 Re: Is this safe to replace with ( fuel lines)
    I've used rubber lines where the plastic ones are leaking before with no problems.
  4. #4 Re: Is this safe to replace with ( fuel lines)
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    why didnt they do that from factory..........im thinkin safety,
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  5. #5 Re: Is this safe to replace with ( fuel lines)
    GT Level Member WolvesSoulZ's Avatar
    Québec
    You don't need anything to cause fires on 3800
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  6. #6 Re: Is this safe to replace with ( fuel lines)
    Sep 2011
    Copperas Cove, TEXAS
    Seen it done on a Fiero, is this what your asking about?
    Took this pic last weekend.
  7. #7 Re: Is this safe to replace with ( fuel lines)
    I've done it
    I did cut the bulge off the line to have more length of rail to put the hose on.
  8. #8 Re: Is this safe to replace with ( fuel lines)
    Jul 2011
    Michigan
    ^^ yes lol, thanks makes me feel better now
  9. #9 Re: Is this safe to replace with ( fuel lines)
    If you have trouble getting the line right at the plastic to metal, pull your drivers wheel and look at if in the wheel well. I recently did a couple braided conversions in that area. Only caveat was getting the lines out of the plastic cllips by the ABS.
  1. L36 vs L67 fuel lines
    By Mjcanton in forum General Tech Discussion
    Last Post: 06-11-2012, 01:48 PM
  2. Fuel Lines
    By Freddy in forum General Tech Discussion
    Last Post: 05-28-2012, 11:29 AM
  3. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  4. Time to replace brake lines
    By lght1 in forum Brakes/Suspension/Chassis
    Last Post: 04-27-2010, 07:32 PM
  5. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
