Thread: Lights dim and charging system severely taxed when rolling windows up
Results 1 to 3 of 3
  1. #1 Lights dim and charging system severely taxed when rolling windows up
    GT Level Member jdmgtp's Avatar
    MI
    When I roll up all 4 windows at once I can tell my cars charging system is being severely taxed. I can hear the fuel pump slow down, idle drop and the iac open up, all my lights including dash dim and everything electrical slows way down. The only thing I can think of is my alternator is having a hard time keeping up, maybe it's time for a rebuild. What do you guys think?
    2000 GTP, 3.2 pulley, SD headers, 3" exhaust, modded 1.9's, custom CAI, LS6 maf, ported blower/ TB, HPT, 65 lb injectors, E85 in the summer, LM-1 wideband, 180 stat, autolite 104's, GMHD suspension kit. 13.2@104 on street tires w/o ported s/c
  2. #2 Re: Lights dim and charging system severely taxed when rolling windows up
    St. Louis
    I think it's time to pull the door panel and grease all the guides and regulator channel, and then lube the felt guides on the window frame w/ some dry lube. It shouldn't tax the system that much unless the windows are getting sticky and slow. This is also a good killer of window regulators.
    And doing all 4 windows at once will do this, and it's probably just showing up more if the windows are dry to begin with. I never roll all 4 up at once, on any of my cars. 2 at a time max.
  3. #3 Re: Lights dim and charging system severely taxed when rolling windows up
    MI
    It dims the lights even if the windows are all the way up....I even see a difference when I turn on the rear defrost, so it's not just the windows. I'm thinking the alternator is unable to keep up. It's original with 140+ on it so its lived a full life. I can get it rebuilt for 70 bucks by a local guy, so I'm gonna just have it done
  1. Charging System Failure
    By Chadgervais in forum General Grand Prix Discussion
    Last Post: 01-03-2013, 11:51 AM
  2. Charging System Failure Help??
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2012, 06:19 PM
  3. Charging System Failure
    By FriboRage in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2010, 12:29 AM
  4. Charging System Failure
    By missyfisch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2009, 10:27 AM
  5. 2008 GP charging system lights
    By RadoZ71 in forum General Tech Discussion
    Last Post: 01-20-2009, 02:02 PM
