Hi guys, so besides for my cam, i still need to get modified retainers and 105lb valve springs. Besides a new water pump, aluminum coolant elbows, and single timing chain, what else would i need? All of those were recomennded by Paul at PRJ (besides for the single timing chain, he recommended double but im sure singles enough with 105 springs). I was thinking about ZZP's install call that inlcudes:
  • Timing chain dampener
  • 12 COMP CAMS reuseable rocker bolts
  • supercharger gasket (except L36/22)
  • 2 coolant passage O-rings (except L36/22)
  • GM oem aluminum intake gasket set
  • front cover gasket
  • ARP assembly lube
  • valve cover gaskets
  • crank bolt
  • cam bolt
    Also, with the single timing chain, should i just get the chain, or the rollmaster single chain timing set?
