Thread: P1629 and P1673
Results 1 to 10 of 10
  1. #1 Re: P1629 and P1673
    Aug 2018
    PA
    So how do you fix the p1673 code need help I have this code 99 grand prix gt
  2. #2 Re: P1629 and P1673
    Mar 2014
    Tucson
    Quote Originally Posted by fomas View Post
    When you cycle the key, does the "Engine Hot" or "Overheat" (or whatever the warning light for over temp says) light up during the bulb check?
  3. #3 Re: P1629 and P1673
    Aug 2018
    PA
    Quote Originally Posted by BrandonHall10 View Post
    No everything seems fine runs at the right temp 180 thermostat installed.
    there is no over heat warning light just the gauge.
  4. #4 Re: P1629 and P1673
    Mar 2014
    Tucson
    I think we're talking past each other. I just did some reading on the Google. *IF* I'm understanding the code set criteria correctly, the code has nothing to do with the actual engine temperature.
    It is there to warn you that your "Idiot light" in the instrument cluster is malfunctioning. I assume they have a code just for this because nobody pays attention to the actual temp gauge.
    This is why I asked very specifically if the warning light illuminates during the "bulb check" when you start the car.
  5. #5 Re: P1629 and P1673
    Aug 2018
    PA
    I dont think there is a warning light for over heating. There is a low coolant light check engine light but no over heating light. As far as I can tell they all work none
    are unlimited .
  1. 99 gtp p1629 help
    By dboy187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-18-2012, 03:32 PM
  2. p1629 with newly installed built trans
    By 01 GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-11-2010, 07:17 PM
  3. Please help...P1629
    By jessie9284 in forum General Tech Discussion
    Last Post: 06-12-2009, 04:43 AM
