Thread: Alternator bracket s/c n/a same?
Results 1 to 15 of 15
  1. #1 Alternator bracket s/c n/a same?
    SE Level Member Adam D's Avatar
    Jan 2013
    grand rapids mi
    Im going to a pick and pull tomm and looking for a few things mainly a alternator bracket for a gen v swap is the n/a s/c bracket the same?
  2. #2 Re: Alternator bracket s/c n/a same?
    Why would you need to change the alt bracket to run a different supercharger?
  3. #3 Re: Alternator bracket s/c n/a same?
    you only need to change the alt bracket if your installing a IC. on a 97 or 98 i think. gen V will fit if thats all your doing.
    Jan 2013
    grand rapids mi
    I have a 98 the alternator is mounted slightly diffierent from what i understand and the it is difficult to install on the 98 style
    Jan 2013
    grand rapids mi
    At least according to what i read on threads on here its easier with the different style bracket
  6. #6 Re: Alternator bracket s/c n/a same?
    if you change it you will also need the alternator from the newer car.
    no need to tho, it will fit.
    Jan 2013
    grand rapids mi
    http://www.grandprixforums.net/eaton...5-a-49039.html.
    According to this it wont.
    Have you done the swap?
  8. #8 Re: Alternator bracket s/c n/a same?
    his quote.
    7) Alternator
    Unfortunately, the alternator and its bracket can cause some issues when swapping this blower onto your L67. Generally, the 97-98 alternator and bracket will NOT work. The solution is to swap to a 99+ bracket and alternator.
    and his pic.
    you tell me why the alt would be in the way? the dimensions are about the same. like i said earleir, you need to change it if you are adding a IC so the hoses can be run through the belts.
    this thread, talks about that bracket, and has pics of why it needs to be changed, for a IC. thats a inter cooler in case your not sure. you'll see the pipes hit the bracket.
    http://www.grandprixforums.net/spart...-38-40321.html
    pic from thread.
    Jan 2013
    grand rapids mi
    Well i apreciate the info but and glad i dont need more s*** but still confused as to why the thread says i needed it
  10. #10 Re: Alternator bracket s/c n/a same?
    its the internet, its not 100% all the time, hell im even wrong sometimes, but this im pretty sure about.
    im planning on this swap myself with another engine i want to build up some. so i ve looked up all this stuff myself already., and i have a 98, so if i get a ic ill be changing the bracket and alt. if my new engines not newer.
    Jan 2013
    grand rapids mi
    Well i apreciate the info. I suppose i wasnt gonna question such a well thought out thread
    Jan 2013
    grand rapids mi
    Maybe you guys could answer this question to are the bolts the same for the l32 lim to bolt to engine?
  13. #13 Re: Alternator bracket s/c n/a same?
    Yes.. same 12 LIM bolts. The only thing different on an L32 manifold from an L67 manifold is the size of the opening in the top.
    Jan 2013
    grand rapids mi
    Thanks for the info
  15. #15 Re: Alternator bracket s/c n/a same?
    And yes..the bracket is teh same NA to SC as well.
  1. Alternator Mounting Bracket/tensioner bracket removal
    By USMarine430 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2012, 01:59 PM
  2. Alternator Bracket
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2010, 01:55 AM
  3. Alternator bracket?
    By Pure2sin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-14-2010, 01:25 PM
