his quote.
7) Alternator
Unfortunately, the alternator and its bracket can cause some issues when swapping this blower onto your L67. Generally, the 97-98 alternator and bracket will NOT work. The solution is to swap to a 99+ bracket and alternator.
and his pic.
you tell me why the alt would be in the way? the dimensions are about the same. like i said earleir, you need to change it if you are adding a IC so the hoses can be run through the belts.
this thread, talks about that bracket, and has pics of why it needs to be changed, for a IC. thats a inter cooler in case your not sure. you'll see the pipes hit the bracket.
http://www.grandprixforums.net/spart...-38-40321.html
pic from thread.
