Thread: 5 volt(a or 1) circuit code
Results 1 to 2 of 2
  1. #1 5 volt(a or 1) circuit code
    Jan 2013
    Needmore Pa.
    Ok the fuel gauge guy again. Im getting the code in the title and have replaced the fuel sending unit the tps and the map sensor. Still have high idle and the fuel gauge still goes from full to empty at start up. Now what? Replace the pcm? I did notice that if I unplug the tps the idle will go back to normal but its new so Im still lost.
  2. #2 Re: 5 volt(a or 1) circuit code
    Hi fuel gauge, already have a post about this issue guy ....again.
    Please keep one issue in one thread. Reason behind it is.. people are responding over there, no reason for two responses in two places then possibly another person making suggestions that get overlooked, you saying... tried that... etc .
    Makes it easier for the people helping you.
  1. P0463 Fuel Level Sensor Circuit High Voltage = ECM, PCM code
    By WonBadGTP in forum General Tech Discussion
    Last Post: 02-14-2011, 08:41 AM
  2. po341 cam sensor circuit code
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2009, 12:07 AM
  3. Code P0102 - Mass Air Flow Sensor Circuit Low Frequency, emissions next week!
    By Quicklynx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2009, 07:00 AM
  4. P1810 Trouble Code - TFP Valve Position Switch Circuit
    By DanGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-19-2008, 11:03 PM
  5. 12 Volt Remote
    By mainecrab in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2008, 09:45 AM
