Thread: A/C not working!! what could be the problem
Results 1 to 5 of 5
  1. #1 A/C not working!! what could be the problem
    Banned
    Jan 2013
    maryland
    Hey guys i wanted to ask what could be a reason why the a/c isnt working? Blower motor? Relay? Etc? I was told it may be a blower motor but i need a fix quick as here in DC its getting cold as S**t oh yeah i have a 2001 grandprix gtp thanks!!
  2. #2 Re: A/C not working!! what could be the problem
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Your Air Conditioning isn't working, or the fan that blows the air?
    If your actual A/C isnt working, could be the condenser?
    But if its your fan, the blower settings are vacuum powered i believe, there is a Vac line under the hood for that you can check.
    Your blower motor could also be going bad.
    Does the fan work on all settings?
  3. #3 Re: A/C not working!! what could be the problem
    Banned
    Jan 2013
    maryland
    Its the fan and you said something about a vac line where is it located? When i turn the knobs to different levels of like from less to more 1 to 5 high to low when i do the first time i start for the car it makes a noise then if i try turning the knobs to hear the voice again it doesnt make any noises so it might be fan what would need to be replaced?
  4. #4 Re: A/C not working!! what could be the problem
    sounds like the fan motor took a dump. its behind the glove box.
    the vac line only controls the air direction. floor, vent, defrost type stuff.
  5. #5 Re: A/C not working!! what could be the problem
    Jun 2011
    Sounds like a blower motor to me.
  1. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  2. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  3. Replies: 1
    Last Post: 01-11-2012, 11:38 PM
  4. site working and then not working etc.
    By Rocket468 in forum Site/Club News
    Last Post: 03-24-2010, 11:53 PM
  5. problem #2.. #5 on heat control not working
    By simplyfamous in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-23-2009, 12:13 PM
