I've had these same lights come on in my '00 GT. It's obviously a code for an error. From what I've researched on the internet (sorry about not having sources!) it has to do with your ABS sensor. It could be from a single bad reading or multiple bad readings. Check your wiring for visible breaks or disconnects. I'm unsure of whether or not a reset by a computer is necessary, but it will show you the exact problem. Also, removing fuses does absolutely nothing. Hoped this helped at least a little.
