Thread: ABS/Traction control lights on and don't know how to fix!
Results 1 to 10 of 10
  1. #1 ABS/Traction control lights on and don't know how to fix!
    Jun 2012
    United States
    Hello all, I am having a slight issue with my car.
    I had a blowout about two weeks ago. (left front) After that incident my ABS/Traction control lights come on. I checked the fuses and all is well there.. any recommendations on what I should try next?
    Think maybe when the tire blew out it messed up a sensor?
  2. #2 Re: ABS/Traction control lights on and don't know how to fix!
    Max Cook
    Guest
    Wheel bearing. Sensor or hub, either way get it scanned to find out which one specifically.
  3. #3 Re: ABS/Traction control lights on and don't know how to fix!
    The blow out prolly took the wire harness with it. Check for broken wires on the tire that blew out.
  4. #4 Re: ABS/Traction control lights on and don't know how to fix!
    Nov 2012
    Frederick, MD
    The ABS wiring harness run on top of the lower control arm. With age, the wiring insulation gets brittle and could easing break upon impact from a blown tire. A few years back, I had a problem with the ABS and TCS going out while turning at low speeds while parking. GM makes a connector with enough wire to go from the hub/sensor to the harness on the front of the subframe. A damaged wire harness may cause the hub sensor to fail. Unfortunately, the sensor is in the hub. I had to replace the connectors and hubs on both side to fix my problem.
  5. #5 Re: ABS/Traction control lights on and don't know how to fix!
    Nov 2012
    Frederick, MD
    BTW - my problem started after I had the transmission replaced. There was no visible sign of damage to the harness. I was able to determine the harness was bad by checking continuity at the connector near the hub and where wire for the connector left the harness on the subframe.
  6. #6 Re: ABS/Traction control lights on and don't know how to fix!
    Jun 2012
    United States
    Just jacked it up and checked wiring harness, still intact.. car dealership wants $50 just to hook it up to their machine.. so guess i'll be heading there to find out the issue. Thanks for the help guys!
  7. #7 Re: ABS/Traction control lights on and don't know how to fix!
    Apr 2012
    Goderich, Ontario
    I've got this same issue on the wife's 02GT. ABS & trac. light came on yesterday then went out today. Break fluid level is good and I put 2 new wheel bearings in this summer. Maybe just cold weather?
    Sorry robinson220, not trying to jack your thread. Doesn't make sense to make 2 threads about the same problem.
  8. #8 Re: ABS/Traction control lights on and don't know how to fix!
    GTP Level Member joe0813's Avatar
    Boston, MA
    Quote Originally Posted by smoke14 View Post
    Cold weather or brake fluid level would have nothing to do with your ABS/Trac light... these cars have pretty common issues with the wiring from the bearing. and the Ebcm shiit the bed too
  9. #9 Re: ABS/Traction control lights on and don't know how to fix!
    Jun 2012
    United States
    Didn't take the time to search for a thread with same issues.. so my apology for jacking your thread.
  10. #10 Re: ABS/Traction control lights on and don't know how to fix!
    Jan 2013
    Brookings, SD
    I've had these same lights come on in my '00 GT. It's obviously a code for an error. From what I've researched on the internet (sorry about not having sources!) it has to do with your ABS sensor. It could be from a single bad reading or multiple bad readings. Check your wiring for visible breaks or disconnects. I'm unsure of whether or not a reset by a computer is necessary, but it will show you the exact problem. Also, removing fuses does absolutely nothing. Hoped this helped at least a little.
  1. abs/traction control lights on??
    By zraymond09 in forum General Tech Discussion
    Last Post: 01-17-2013, 09:35 PM
  2. ABS and Traction Control Lights
    By MBigelow in forum General Tech Discussion
    Last Post: 07-27-2012, 07:18 PM
  3. ABS/Traction control lights
    By thirdrail37 in forum Brakes/Suspension/Chassis
    Last Post: 06-28-2011, 01:00 AM
  4. ABS & Traction Control Lights
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2009, 06:40 PM
  5. '99 GT - ABS/Traction Control Lights
    By Sparg93 in forum General Tech Discussion
    Last Post: 01-15-2009, 06:21 PM
