Thread: Annoying Starting issue! Please help!!!!
Results 1 to 6 of 6
97gtpfreak Annoying Starting issue!... 01-19-2013, 07:26 PM
Fivefingerdeathpunch Re: Annoying Starting issue!... 01-19-2013, 07:28 PM
dsmuts Re: Annoying Starting issue!... 01-19-2013, 07:31 PM
97gtpfreak Re: Annoying Starting issue!... 01-19-2013, 07:37 PM
Slappyn Re: Annoying Starting issue!... 01-19-2013, 09:01 PM
Seachicken Re: Annoying Starting issue!... 01-19-2013, 10:24 PM
  1. #1 Annoying Starting issue! Please help!!!!
    Indianapolis, Indiana, United States
    Okay so a few weeks ago my 97 GTP decided it dididn't want to start well come to find out the starter was starting to go out. Well then the battery took a shi* so we replaced the battery and the starter is still slowly going out so the husband gets a starter for it we replace it and now it's still doing the whole turn key over "click" "click" "click" and eventually it starts after 8-10 turnovers any suggestions what the problem could be? Any help is greatly appreciated! Thanks
    “I don't mind living in a man's world, as long as I can be a woman in it.”
    -Marilyn Monroe<3
  2. #2 Re: Annoying Starting issue! Please help!!!!
    Check the wiring, He may have a loose wire or a bad ground.
  3. #3 Re: Annoying Starting issue! Please help!!!!
    How was your starter slowly going out? Ususally they either work or they don't. Also it could be an ignition switch.
  4. #4 Re: Annoying Starting issue! Please help!!!!
    I will have them look into those ideas and dsmuts because when it started doing the click click and eventually have to get under the car and hit the starter it would start but before he changed the starter I would have to put the car in neutral and push it back or forth and it would start but it is very annoying to be at the store or somewhere and get in the damn car and try to start it all it does is click lol
    -Marilyn Monroe<3
  5. #5 Re: Annoying Starting issue! Please help!!!!
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    Autoparts stores will test the starter. I had the same issue when I dropped in my new motor which boiled down to loose ground to the transmission. Sounds like the neutral safety start switch may be at fault and worth a look if the simply measures dont work. The starter needs current to work so it can be tested with a digital multi meter and some you tube video as well as manuals such as the haynes manual to figure it all out.
  6. #6 Re: Annoying Starting issue! Please help!!!!
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    ignition switch, crank relay, pnp switch and pcm are all part of that circuit.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Starting issue
    By Zach Chapman in forum General Grand Prix Discussion
    Last Post: 12-25-2012, 10:11 AM
  2. Please someone help me out here, starting issue.
    By Brickie in forum General Tech Discussion
    Last Post: 01-12-2012, 12:10 AM
  3. Please someone help me out here, starting issue.
    By Brickie in forum Off Topic Discussion
    Last Post: 01-09-2012, 12:30 PM
  4. Starting issue
    By GTP Ryan in forum General Tech Discussion
    Last Post: 08-28-2011, 02:55 AM
  5. Starting issue
    By MuTaLiZeD in forum General Tech Discussion
    Last Post: 07-31-2009, 01:03 AM
