Thread: trans cooler line leaking
Results 1 to 9 of 9
_nick_ trans cooler line leaking 10-17-2008, 06:59 PM
BADAZGTP Re: trans cooler line leaking 10-17-2008, 08:05 PM
_nick_ Re: trans cooler line leaking 10-17-2008, 09:08 PM
BADAZGTP Re: trans cooler line leaking 10-17-2008, 09:23 PM
kyle99gtp Re: trans cooler line leaking 10-17-2008, 11:05 PM
Blown97 Re: trans cooler line leaking 10-17-2008, 11:38 PM
streetsmart Re: trans cooler line leaking 02-18-2009, 01:19 PM
mike2pin Re: trans cooler line leaking 09-21-2011, 09:36 AM
BillBoost37 Re: trans cooler line leaking 09-21-2011, 09:58 AM
  1. #1 trans cooler line leaking
    I noticed something oily at the bottom of my radiator and its transmission fluid...on further inspection it looks like the bottom cooler line is leaking where it goes into the radiator. It looks a bit rusty about an inch back from the fitting before the bend. Can I just purchase a new fitting or do I need a new line? How do I remove the line from the radiator?
  2. #2 Re: trans cooler line leaking
    Apr 2008
    Chillin at the Beach , VA
    You'll have to get a whole new line. And the fitting just unscrews from the radiator. I'd pull the line off, wire brush the rust off and see if you can see any holes in it before purchasing a new one. Also check out where it screws into the radiator a little closer .
  3. #3 Re: trans cooler line leaking
    The line connects to another line under the radiator correct? or is it one peice all the way to the transmission? Also, I guess this question is for trannyman but any input is appreciated...Should I just ditch the internal cooler and go with a small axillary cooler down in front? The only downfall I can see going this route is having to let the car warm up a bit longer in the winter
  4. #4 Re: trans cooler line leaking
    Apr 2008
    It's all one line. There is no need to run the external cooler. I have one on mine, but everyone I've talked to said it's a waste.
  5. #5 Re: trans cooler line leaking
    NE Ohio
    its a waste and can actually cause more problems that help anything. they have a bad tendancy to leak and then youre in trouble..
  6. #6 Re: trans cooler line leaking
    Feb 2008
    yeah just fix or repair the line and remember to add the fluid that you lost!!
  7. #7 Re: trans cooler line leaking
    SE Level Member streetsmart's Avatar
    Apr 2008
    Red Lion, PA
    Does anyone know the part #'s for the 2 tranny cooling lines that run from the tranny to the radiator and back? I need to replace mine on my 04 Comp G, but I can't seem to find the part # to order on the GM site....
    Thanks!
    01 GT Black 2 DR
    98 GTP Black 4 DR
    04 Comp G Black 4 DR
    I just can't seem to get my fix!
  8. #8 Re: trans cooler line leaking
    SE Level Member mike2pin's Avatar
    Apr 2011
    NB, Canada
    I'm having cooling problems too on my 00 GP GT they were rotted. SO what I'm doing rather than replacing the factory lines (@ dealer are around $100 each!), I bought new connectors on the tranny side from GM(Ac Delco 24213958 & 24233366), reusing the Rad side connectors(they're in good shape), going to Mister Transmission and buying 4 pieces of line about 2 inches long with the flare/bubble that clicks into the connectors and using 2 4 foot pieces of Russell Stainless Steel hose to connect it all(hose just clamps onto pipe extruding from connectors). LOOKS better than stock, and all under $100 bucks!!
  9. #9 Re: trans cooler line leaking
    Trans lines are not that expensive. You need to check another dealer.
    Closing the 2 year old thread for you too.
  1. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
  2. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
  3. Puffffffft...I can make that cheaper and cooler
    By GR8racingfool in forum Off Topic Discussion
    Last Post: 06-02-2008, 07:03 PM
  4. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
