Thread: strange misfire problem
Results 1 to 20 of 21
  1. #1 strange misfire problem
    utah
    So I have a random issue. Sometimes, for no reason at all my car will misfire like a mofo and barely chug along unless I mash the gas then it runs fine, no misfire. But if I just drive normal it chugs and chugs. Then the problem goes away. No cell....I'm lost on this one
  2. #2 Re: strange misfire problem
    The Boss Iceman6669's Avatar
    Jun 2011
    I had a similar problems and I deleted the EGR and all my problems went away...
  3. #3 Re: strange misfire problem
    utah
    Might have to do that. Just makes emissions a pita
  4. #4 Re: strange misfire problem
    Jun 2011
    Yeah, Lucky for me I live in MI where there are no emissions testing. If you have a tuner I have a good idea how to get away with it...
  5. #5 Re: strange misfire problem
    your dam sure the plugs not broke in anyway or you have a bad wire????
  6. #6 Re: strange misfire problem
    take a spray bottle with a salt water mix and soak down the engine and look for arcs and see if anything changes and do it all night or just somewhere dark
    SMGPFC Member #10
  7. #7 Re: strange misfire problem
    May 2011
    Chicago, IL
    I had the same exact problem with my car. had random misfire and went away and came back off and on. replaced plugs wires (needed done anyways). checked all the coils. i went through everything. then a lean code came up. checked all vac lines with carb clean. absolutely nothing and still had the random misfire. Started with the carb clean again and sprayed right under the s/c snout. s/c gasket was leaking. replaced it and everything went away. what was weird is that the lean code never came up for a good week or 2 after it all started lol. Not saying thats whats going on with you just thought it was interesting that the random misfire on 6 was the only code it threw lol
  8. #8 Re: strange misfire problem
    utah
    ive checked for vac leaks. couldnt find any. plugs are a week old. checked them all they are fine. checked wires as well. coils are fine. ignition plate is golden....tried everything i could think of to produce the problem and it just does it when it wants to. drove over 300 miles today...freaking retarded
  9. #9 Re: strange misfire problem
    Omaha, NE
    Mine does this. I also haven't found a solution. No vac leaks.
    Things I've replaced:
    MAF
    Wires
    Plugs
    Coils
    I think I'm going to re-gap my plugs and try again.
  10. #10 Re: strange misfire problem
    utah
    im gonna try deleteing the egr and see if that helps. also replace my 02...for the like 50th time. but for now im just gonna drink a bunch of soco and pretend i have a ctsv in my garage instead
  11. #11 Re: strange misfire problem
    Don't replace anything unless you need to....is the TB all gunked up? Have you ever cleaned it? With no CEL its kinda tough to even get an idea of where to start since you've checked all the obvious wbody issues....
  12. #12 Re: strange misfire problem
    utah
    the tb is fine. might try switchin it out seein as i have another to see if that fixes it though
  13. #13 Re: strange misfire problem
    Sounds ignition related.
    Start with plugs and wires usually.
    Move on to checking vacuum leaks if you think they can exist
    Always clean the coil towers if they are cruddy
    Then consider swapping the ICM with a known good one. ICM's can cause a single cylinder misfire. It's not common, but can happen.
  14. #14 Re: strange misfire problem
    utah
    All cylinders misfire when the problem exists
  15. #15 Re: strange misfire problem
    Sep 2011
    Canada
    Your cat could be plugged! Had the same engine code and symptoms on my wife's Grand AM GT when hers was plugged.
  16. #16 Re: strange misfire problem
    All cylinders you say?
    Check fuel pressure with a lengthened gauge to drive around and watch.
  17. #17 Re: strange misfire problem
    Quote Originally Posted by mrfreez View Post
    He has pacesetters and full exhaust...I doube he is running a converter.
  18. #18 Re: strange misfire problem
    Feb 2009
    flintnasty MI
    a multiple misfire under high load will typically be related to extreme rich conditions in my experience.
  19. #19 Re: strange misfire problem
    Or lean
  20. #20 Re: strange misfire problem
    But lean...is mean lol
  1. 2004 GTP strange problem
    By dakcornholio in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2011, 05:46 PM
  2. Strange steering problem
    By tccmn in forum General Tech Discussion
    Last Post: 07-09-2011, 02:24 PM
  3. strange problem
    By LSXHP in forum General Tech Discussion
    Last Post: 01-15-2011, 01:35 AM
  4. Strange transmission problem
    By fishman517 in forum General Tech Discussion
    Last Post: 11-18-2010, 06:20 PM
  5. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
