Thread: Washer Fluid Injection
Results 1 to 9 of 9
  1. #1 Washer Fluid Injection
    Highland Heights, KY
    I didnt believe it. I went to my shop put some washer fluid in a spray bottle-on a super pfine mist, with a lighter it sure enough does.
    Now who is running it, i know it sounds silly. Is anyone running on our v6's. Im just curious to see the outcome on a non SC or Turbo CAR.
    Id like to see some pics though and parts used. Just out of curiousity. THANKS
  2. #2 Re: Washer Fluid Injection
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    It is the same concept as water/meth/alky injection. I have read of this being done plenty with the cold weather washer fluid.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Washer Fluid Injection
    in how to's here. i couldnt't find any, or any budget kits......
  4. #4 Re: Washer Fluid Injection
    Feb 2008
  5. #5 Re: Washer Fluid Injection
    Ohio
    With one of these kits are there any kind of supporting mods you should have first or can anyone just go slapping on a meth kit?
    00 GTP demodded and forsale
  6. #6 Re: Washer Fluid Injection
    Quote Originally Posted by speedemongtp View Post
    ALSO my question. Found the kit i want but what else do i need "supporting mod". or is just this kit fine. Also when the say water/meth/alchy that meas i can use any of them but drain all of the other before switching right.
    Im sure like nitris i need a colder plug. Any other advise would be great or forwarded to another THREAD.>>
    thanks
  7. #7 Re: Washer Fluid Injection
    Ohio
    DevilsOwn alcohol water injection- methanol You may also want to check these out
  8. #8 Re: Washer Fluid Injection
    Bastard Reptile's Avatar
    Kansas City, MO
    You don't need colder plugs, just a tuner to help you with it. If you start out straight washer fluid, use a smaller nozzle because you don't want to retard the combustion flame too much....the more methanol you use the bigger the nozzle you want to use.
    But if you want to put it on your GT, it's pretty much pointless. Forced induction is where this helps out.
  9. #9 Re: Washer Fluid Injection
    Ok, really thats what i was wanting to know, i should have asked that. i was looking in to SCing it but i didnt add that in. THANKS
  1. Ethanol injection
    By IndeedSS in forum Off Topic Discussion
    Last Post: 09-03-2008, 09:45 AM
  2. Attaching fittings on washer style bottle...
    By Iron Indian in forum General Tech Discussion
    Last Post: 07-20-2008, 08:13 PM
  3. Changing washer bottle from 97-98 style to 99+
    By Zef_66 in forum General Tech Discussion
    Last Post: 05-30-2008, 10:03 AM
