Thread: interior lights stay on after getting in.
Results 1 to 14 of 14
  1. #1 interior lights stay on after getting in.
    Dec 2011
    chicago
    So recently I go to get in my 98 gtp, and the interior lights stay and I have to pull the fuse it get it to go off. Anybody ever had this? Figure either a door switch or bcm maybe? Thats for the help.
    I live here. DirtDog's Avatar
    Jun 2012
    Make sure the light adjuster knob isn't turned on...its on left side of the dash
    Sent from my DROID RAZR using Tapatalk 2
  3. #3 Re: interior lights stay on after getting in.
    Dec 2011
    chicago
    Well I doesn't do it all the time. Sometimes it dims away like its supposed, sometimes not.
    Jun 2012
    Maybe a bad dimmer switch...
  5. #5 Re: interior lights stay on after getting in.
    Dec 2011
    chicago
    I doubt that its the switch, but I'm gonna get a wiring diagram
    Jun 2012
    Quote Originally Posted by ls1racer11 View Post
    Yea either that or a wire loose somewhere which would explain why setimes it stays on
  7. #7 Re: interior lights stay on after getting in.
    Earth
    Did you have any luck figuring this out? I have a 2001 doing the same thing and am leaning towards the BCM since it even does it occasionally with the keyless entry and trunk lid along with a random combination of doors
    2001 Pontiac Grand Prix GTP
  8. #8 Re: interior lights stay on after getting in.
    Mar 2014
    Tucson
    Experiencing the same issue... Also, after pulling the fuse, the lights will stay barely lit. They're LED's if that matters.
    Anyone have any luck?
  9. #9 Re: interior lights stay on after getting in.
    Mar 2014
    Tucson
    Quote Originally Posted by Booba5185 View Post
    All the doors closed? Try hitting the lock button on the doors, if you hear 3 dings then one of the doors isn't being seen as closed.
    Just tried that. Dings with the door(s) open. Locks instantly with the door(s) closed. Also, could a bad door lock actuator be back feeding current to the courtesy lights?
  10. #10 Re: interior lights stay on after getting in.
    Earth
    I ended up fixing mine after taking the door panels off to replace/test speakers. The door lock switch was broken by the previous owner so I fixed it and I had some bad connections in the passenger door and it has worked every time since, except when I hit the dimmer switch that one time a month later
  11. #11 Re: interior lights stay on after getting in.
    hangover park IL
    scan bcm for door switches working, usually its the drivers door sensor/switch
    ~James~ Psychotic Gearhead
  12. #12 Re: interior lights stay on after getting in.
    Mar 2014
    Tucson
    Forgive me, I'm still learning. Wouldn't the DIC show the door as "open"?
  13. #13 Re: interior lights stay on after getting in.
    Mar 2014
    Tucson
    Now I"m thinking it could be my made in china LED's. I pulled just one of the 6 courtesy lights, and replaced with a standard 194 incandescent, and they all act like they should.
    I'm going to replace all courtesy lights back to standard bulbs and see if that fixes my problem.
  14. #14 Re: interior lights stay on after getting in.
    Mar 2014
    Tucson
    Changed just one bulb back to incandescent, and all is well. Considering problem solved... for now.
  1. abs and traction control lights stay on
    By John Emma in forum General Tech Discussion
    Last Post: 09-12-2012, 11:25 PM
  2. Wiring fog lights to stay on with brights
    By danielle15 in forum General Tech Discussion
    Last Post: 01-11-2012, 03:26 PM
  3. interior lights/exterior lights newbie question
    By spider4 in forum General Tech Discussion
    Last Post: 11-10-2011, 08:34 PM
  4. 06 lights won't stay on
    By cooney in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2009, 07:25 AM
  5. Hit pothole..now ABS and TRAC OFF lights stay on
    By abuckley1290 in forum General Tech Discussion
    Last Post: 06-15-2009, 11:07 PM
