Thread: Hit pothole..now ABS and TRAC OFF lights stay on
Results 1 to 12 of 12
  1. #1 Hit pothole..now ABS and TRAC OFF lights stay on
    SE Level Member abuckley1290's Avatar
    Jul 2008
    So just as the title says i hit a pothole and now these two lights are on. They usually come on right when i go into drive if not a few moments later. What could the problem be....? thanks
    40th Anniversary GP
  2. #2 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Elkhorn,WI
    Sounds like you messed up a bearing. The abs sensor is a part of the wheel bearing asm. Or you have a bad connection or rubbed wire at a sensor. If the abs gets irronious readings from a sensor your tcs is also disabled with abs.
  3. #3 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Jul 2008
    I also noticed that under moderate to firm braking the steering gets alot tighter and a bit harder to control..which never happened before the lights came on.
    40th Anniversary GP
  4. #4 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    TDCRacing
    Guest
    Make sure the variable effort steering harness is hooked up. Ther are two wires and a plug that come off of the rack and pinion. It's kind of hard to get to but can be accesed from under the car.
  5. #5 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Elkhorn,WI
    It is also possible that the speed sensitive steering is affected by the irronious readings from the wheel speed sensors. Seeing as the firmness fo the steering changes with your speed.
  6. #6 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Willoughby, Ohio
    i just replaced a bearing a few days ago and just as u said when breakin or even cornering it was harder to stear...now its so much easier to drive...id check that bearing
  7. #7 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Jul 2008
    which bearing?
    40th Anniversary GP
  8. #8 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Charles City, IA
    It would be a wheel bearing for the abs/ trac off light.
    SMGPFC Two Nipple General
  9. #9 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Elkhorn,WI
    You now need to have the codes scanned to see which sensor is acting up.. I'd take it to autozone or some place free. This is something simple that they can't screw up!
  10. #10 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    he needs to check the connections on the bearings.. perhaps replace one.
  11. #11 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Scottdale, PA
    I just fixed ths problem on my 97 GP GT and it wound up being something stupid. I got up under the car with the tires in the front all the way to the left or right and i found that the Wheel speed sensor was not where it was supposed to be. Clipped it back up to the spot it is supposed to be and now those lights went off no problems since that.
  12. #12 Re: Hit pothole..now ABS and TRAC OFF lights stay on
    Jul 2008
    Quote Originally Posted by Subzero121800 View Post
    Actually, i noticed the same exact thing but i couldnt get it back in so i thought nothing of it...i'll have to look at it again
    40th Anniversary GP
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. 06 lights won't stay on
    By cooney in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-27-2009, 07:25 AM
  3. trac control
    By mileyguard in forum General Tech Discussion
    Last Post: 03-24-2009, 12:02 PM
  4. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
  5. Trac Off Issue
    By catcamvegas in forum General Tech Discussion
    Last Post: 07-25-2008, 10:01 AM
