Thread: L32 t/b pic
Results 1 to 9 of 9
  1. #1 L32 t/b pic
    Donating Users blowfishRus6's Avatar
    g.a.
    figured i show you guys what one looks like off the car. mesaured in right at 3in.
    inside the eaton, ehh it needs a cleaning. good thing its comming off soon
    do those humps need to be in there???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: L32 t/b pic
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    yea thats what mine looked like but a little worse. After a good cleaning it was sparklinggggg.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  3. #3 Re: L32 t/b pic
    Jul 2008
    sumter,south carolina
    is there anything special that u clean s/c with?
    02 GTP with mods 05 GP for DD
  4. #4 Re: L32 t/b pic
    Barksdale AFB, LA
    Intake cleaner. Available at any parts store in many brands.
    2009 Subaru Impreza WRX STI
  5. #5 Re: L32 t/b pic
    Feb 2008
    South Bend, IN
    I used B-12 Chemtool. The bottle on the Chemtool said that it leaves no residue. The back of every other bottle of intake cleaner that was on the shelf said that it did leave a residue. Not sure what the residue is but I dont like the sound of it so I chose the Chemtool.
    Remember to let the car sit for a few hours after you clean it to let the excess dry up. The first start will be a long start, just hold the key down till the engine fires up. Then let the car sit and warm up to "burn off" the excess cleaner if there is any.
  6. #6 Re: L32 t/b pic
    g.a.
    another question i have is can the inside, the inlet side of the supercharger with the humps, can those be sanded down or do the humps serve a purpose for the fuction of the supercharger???
    its slow.
  7. #7 Re: L32 t/b pic
    g.a.
    soooo no porting out the humps in the supercharger huhh???
    its slow.
  8. #8 Re: L32 t/b pic
    Hoffman/Schaumburg, IL
    The humps have the S/C bearings in them, you can smooth the surface if you want, but they are there to optimize air flow to the right part of the rotors, and if you cut into the bigger ones, you would get to the bearing pretty quick, sadly the Gen V is pretty optimized and there is little/nothing to port, or perfect on them, sorry
  9. #9 Re: L32 t/b pic
    g.a.
    thanks. thats what i was looking for
    its slow.
