Thread: opinions on this stuff
Results 1 to 7 of 7
  1. #1 opinions on this stuff
    I live here. DirtDog's Avatar
    Jun 2012
    what yall think of this
    Home » Engine Cooling Systems
  2. #2 Re: opinions on this stuff
    Omaha, NE
    Up to 10% of 21 (estimated combined MPG) is "up to" 2.1mpg I don't really see that out of coolant alone.
    In a daily driven vehicle you want it to get up to 195 degrees for optimum economy. That's why its the stock temperature.
    As for the performance cooling factor... Probably not enough to make the cost worth it.
    The cooling system holds 10.6 liters, thats 2.8 Gallons. At $43.95 per gallon, a change to this stuff would cost $131.85 plus $24.86 Shipping for a total of $156.71.
    Jun 2012
    U really looked into it a lot. I didn't even pull up prices. I didn't think coolant alone could make as big of an impact as they were saying. But yea that's dang expensive
    Sent from my DROID RAZR using Tapatalk 2
  4. #4 Re: opinions on this stuff
    Omaha, NE
    Not really, just did some simple math and looked at the prices on the link you post...
  5. #5 Re: opinions on this stuff
    Destroys cars izup69's Avatar
    Iowa
    I have seen this stuff used before. It alows you to open your rad while the car is hot WOW. But it is also a true lifetime coolent. As in never have to change it out. It might be worth it in a new car. It would take a while to pay for itself. Since most coolents are good for about 2 years.
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  6. #6 Re: opinions on this stuff
    Omaha, NE
    Keep in mind you should flush your coolant when you replace your intake manifold gaskets. Dealers usually reccomend this around every 60k miles. That leaves you paying $156.71 every 4 years assuming you drive the "average" of 15k miles a year.
    I'll stick to $32 ($15.99 per gallon) of Prestone Dex concentrate and mix in some water and call it a day.
    Jun 2012
    O I know I flush mine and the 16 dollar a gallon stuff works just fine
  1. Roof Rails and 40th Anniversary Stuff.How much can i sell this stuff for on ebay?
    By indygrandprix in forum General Grand Prix Discussion
    Last Post: 09-16-2012, 10:12 PM
  2. painted some stuff... opinions
    By thedudeSE in forum Visual/Body Modifications
    Last Post: 04-29-2011, 12:15 AM
  3. About to order a BUNCH of stuff...need some opinions
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2008, 09:39 PM
