Thread: Goodyear heater hose p/n incorrect (97-03)
Results 1 to 2 of 2
mzbk2l Goodyear heater hose p/n... 01-03-2013, 04:22 PM
Fivefingerdeathpunch Re: Goodyear heater hose p/n... 01-03-2013, 04:55 PM
  1. #1 Goodyear heater hose p/n incorrect (97-03)
    Donating Users
    Nov 2011
    Mesa, AZ
    Long time lurker, now I have some info to give back to the forum.
    I have a wholesale account with a parts distributor, and yesterday I ordered a set of Goodyear heater hoses for my '98 GTP. When I went to install them this morning, I found that both hoses had 5/8" inlets and outlets. On the car, both engine fittings are 5/8", but the heater core has the usual 5/8" upper and 3/4" lower.
    I went to Goodyear's website and used the online part number lookup to verify the part number so I could yell at my supplier, but they had sold me exactly what Goodyear calls for on the site. Turns out Goodyear's catalog is wrong.
    I then went to Gates belts and hoses online and used their catalog - they showed the correct heater hose parts, and even listed the inlet and outlet sizes in the catalog. Armed with the correct gates part numbers (19109 = 5/8" x 5/8" and 19110 = 5/8" x 3/4"), I called my supplier back and they were able to cross-reference to the correct Goodyear part number.
    I've just finished installing the hoses, and I can verify that the following Goodyear part numbers are correct:
    64115 (5/8" x 3/4", or lower heater core fitting to engine)
    64119 (5/8" x 5/8", or upper heater core fitting to engine)
    The Goodyear catalog calls for 63115 instead of 64115 - that will get you a straight hose with a 90* bend on each end, and 5/8" outlets on each end. It won't work very well for a 3800 in a GTP.
    If you'd like to do your own online parts research for Goodyear or Gates, the websites are below:
    Goodyear: Goodyear Engineered Product Online Parts Catalog
    Gates: NaviGates
  2. #2 Re: Goodyear heater hose p/n incorrect (97-03)
    A worthy first post.
  1. New Guy/ heater intake hose
    By ssgtarivera in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-06-2012, 02:44 PM
  2. Heater core - which hose?
    By Skrappi69 in forum General Tech Discussion
    Last Post: 04-06-2011, 12:53 PM
  3. Heater inlet hose
    By PatrickMcL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2010, 07:59 PM
  4. Motormite Heater Hose !!HElP!!
    By emitchell365 in forum General Tech Discussion
    Last Post: 09-12-2009, 05:41 PM
  5. Which is the hose the goes to heater core?
    By DesertFox in forum General Tech Discussion
    Last Post: 05-16-2009, 06:08 PM
