Thread: rhythmic squeak
Results 1 to 8 of 8
  1. #1 rhythmic squeak
    Oklahoma
    I have a 1997 GTP with 220k miles that has developed a rhythmic squeak at start-up. It diminishes dramatically after only a few minutes to the point it's almost unnoticeable. The noise is definitely coming from the vicinity of the bell housing and the frequency of the squeak changes with engine speed while in park. The frequency is much slower than engine speed. I'd guess it might be 240 squeaks per minute at idle. Although the noise is rhythmic it's not regular. I removed the belt from the supercharger and the noise is still there so it's not the supercharger.
    Has anyone run into this before?
  2. #2 Re: rhythmic squeak
    Yoga city
    could be thic oil on rockers and such tapping. since its gotten cold i faintly here it more a min then goes away.
  3. #3 Re: rhythmic squeak
    My bed makes the same noise
  4. #4 Re: rhythmic squeak
    Remove the accessory belt and see if the noise is still present.
  5. #5 Re: rhythmic squeak
    Oklahoma
    Thinking more about it today I think this must be something running at camshaft speed, about 400 squeaks per minute. I fixed a problem just like this in a 5.0L Ford. The camshaft position synchronizer was going bad. I've never had any major problem with this car and don't even know if it has a camshaft position synchronizer that could go bad but there must be something that runs off the camshaft that could squeak.
    It's not any of the accessories. The noise is definitely coming from around the bell housing somewhere.
  6. #6 Re: rhythmic squeak
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    take the flywheel cover off and look to see if any thing is loose
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  7. #7 Re: rhythmic squeak
    No junky synchro on these.
  8. #8 Re: rhythmic squeak
    Quote Originally Posted by Mike3 View Post
    stop thinking about it and take the belts off. then run the car for a minute. if the sound is gone, its a pulley gone bad.
  1. Very annoying squeak
    By anoy1nce in forum General Tech Discussion
    Last Post: 06-27-2011, 09:40 PM
  2. Blower fan squeak Fix
    By JoshsGTP in forum How To Write-Ups/Tech Tips
    Last Post: 02-04-2011, 03:53 PM
  3. want to know what my squeak is
    By Fedewaj in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2010, 08:59 PM
  4. Got a squeak that won't go away...
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 10-02-2009, 06:12 PM
  5. 3.4 pulley squeak
    By pacoflyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2008, 12:15 PM
