Thread: how much does my car actually weigh?
Results 1 to 9 of 9
  1. #1 how much does my car actually weigh?
    Aug 2008
    Long Island, New York
    ive found a bunch of different numbers when looking up the weight of my car, its a 2000 GTP 4 door, does anyone know the weight?!?!
  2. #2 Re: how much does my car actually weigh?
    Banned
    Wichita Falls, Texas
    3396 lbs
  3. #3 Re: how much does my car actually weigh?
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Quote Originally Posted by Street Wolf View Post
    3396 lbs
    I think that's dry wieght...... How much do fluids add? Couple hundred pounds????? I thought it was somewhere around 3700...
    Also, IIRC there's only about 100# difference between the 2dr and 4 dr.
  4. #4 Re: how much does my car actually weigh?
    Aug 2008
    wow sick.. it actually weighs alot less than i thought.
  5. #5 Re: how much does my car actually weigh?
    Banned
    Where would a couple hundred pounds of fluid go?
    But yeah, there is a difference between 2 door and 4 door weight.
  6. #6 Re: how much does my car actually weigh?
    Aug 2008
    Portland, Oregon
    That's what I've always wondered, but it always seems like dry wieght and wet wieght seems to vary by a couple hundred.
    Edmunds.com shows curb wieght as......
    2000 GTP Sedan 3414lbs
    2000 GTP Coupe 3396lbs
  7. #7 Re: how much does my car actually weigh?
    Barksdale AFB, LA
    Wet and dry difference also includes gas, which is about 102lbs for a full 17 gallon tank.
    2009 Subaru Impreza WRX STI
  8. #8 Re: how much does my car actually weigh?
    I live here. UR LOSN's Avatar
    Rockford, IL
    the amount of coolant, over 2 gallons of tranny fluid, power steering, oil, etc...... it all adds up....
  9. #9 Re: how much does my car actually weigh?
    SE Level Member tonyfan70's Avatar
    Oct 2008
    Morton IL
    If you want to know your car specifically, try this. If you live around farmland go to the nearest grain elevators...FS or whatever and they have a roll on scale for the grain trucks. When they aren't busy most will let you roll on and weigh. Or you could go to a truck stop. Most have scales and they cost under $10.
    That way you'll know your cars weight with or without you in it and all the fluids and whatever else is in it like a sub box.
    2007 GXP 303hp 5.3L V8.
    1998 Honda Magna VF750C
