My 97 has the ones will the dowel alignment pins but some 97's dont have this. These dowel pins help prevent the gaskets from slipping when installing the manifold. It's up to you, but make sure you buy the aluminum AC delco intake manifold gaskets. The quality of these gaskets are so much better. My 97 gtp I purchased with 34k miles in 2004 or so and the stock gaskets were cracked horribly. Make sure the gasket area is nice and clean before installing new gaskets, also don't forget you MUST apply a gasket maker (I use GM assembly adhesive) to the bottom corners where bottom gasket ends meet. If you don't do this, you WILL DEVELOPE a vacuum leak.
