google would be your new bets friend P0171 - Google Search
start with some carb cleaner, or intake cleaner, and spray around the engines vac lines, if the idle jumps up when spraying, you found the vac leak, the rubber T's like to break, they get dry and brittle over time. if you get nothing, try moving the vac lines a bit while spraying, also spray around the throttle bodys gasket and vac lines as well.
