Thread: Power issues with an 02.
Results 1 to 16 of 16
  1. #1 Power issues with an 02.
    Dec 2012
    Rhode Island
    Ok here is the problem. I have no power.
    The issue is this, When i am driving on a flat level surface the car runs fine. Up hill I loose all power and my grandmother would beat me up a hill in her walker.
    In all seriousness when accelerating lightly the car runs and drives as advertised. When i accelerate harder the enging bogs down and i have no power. going up hill or on a flat surface. I have changed my plugs and wires. Plugs are gapped to spec. I do have a CEL but i have not had the codes read. I will be doing this at lunch and post the codes.
    The reason for the plug and wire change was i got a misfire on #1 cylinder. so instead of changeing one i did all of them to include the #1 coil pack.
    Again any help or insight would be appreciated.
    Thanks
  2. #2 Re: Power issues with an 02.
    Mar 2012
    NC
    Remove the front O2 sensor from the rear exhaust manifold...this will create an awesome exhaust leak. Go drive car uphill.
  3. #3 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    why would i remove the sensor?
  4. #4 Re: Power issues with an 02.
    Mar 2012
    NC
    I think it sounds like you have a clogged cat.
  5. #5 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    Oh i forgot to mention. I disconnected the MAF sensor and it seemed to be running a little better. but not much
  6. #6 Re: Power issues with an 02.
    Jul 2012
    Chicago
    Tap on your cat. If it rattles it's bad.
    -Carl
  7. #7 Re: Power issues with an 02.
    I'm in agreement it sounds like a pissed off feline
  8. #8 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    Ill check it at lunch
  9. #9 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    UPDATE..
    I had my CEL codes checked at lunch. I got the following codes
    P0102 MAF - I got this probably because i have it unpluged
    P0301
    As far as the P0301 goes I have changed within the past 30 - 60 day the following: Plugs, Wires, #1 Coil pack. While i was at Autozone i checked my Fuel pressure and pre start it was at 52 and after start it did not move.
    I can properly hit the cat without being at home so no update on that.
    I did check my MAP sensor though and it seemed loose so i removed it to check the rubber and it seemed fine. I also checked the housing for the MAP and it to seemed loose so i removed that and popped it back in. The both seem really loose to me but another opinion on how they are supposed to be fitted would be great.
    Thanks again
  10. #10 Re: Power issues with an 02.
    Going to think you are NA and not SC. The MAP should be tight. The cap should be tight. There is a rubber o-ring below the pcv, then the pcv, a spring an o-ring on the cap, then the map on the cap.
  11. #11 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    Going to think you are NA and not SC?
    and it should be tight and no wobble whats so ever?
  12. #12 Re: Power issues with an 02.
    Naturally Aspriated vs Super Charged.
    Right..tight as in a pain to turn the cap
  13. #13 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    It was easy to turn so maybe i should start there.
  14. #14 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    Fixed the codes.
    when i hit the cat with a hammer it sounds like there is a marble inside of it
  15. #15 Re: Power issues with an 02.
    Dec 2012
    Rhode Island
    Cat was plugged. I replaced it. now i just need to weld it in place
  16. #16 Re: Power issues with an 02.
    Clamps will hold.
  1. Power window issues
    By 7point62 in forum General Tech Discussion
    Last Post: 07-28-2013, 11:00 PM
  2. Power Steering Issues
    By cpr in forum General Tech Discussion
    Last Post: 01-29-2012, 01:29 PM
  3. K got power steering issues...
    By DaytonaGTP in forum General Tech Discussion
    Last Post: 12-17-2009, 03:44 PM
  4. Power window issues
    By dbinnc in forum Audio, Security & Visual Electronics
    Last Post: 08-29-2009, 10:04 AM
  5. Power window ISSUES!
    By AR15 guy in forum General Tech Discussion
    Last Post: 06-17-2008, 02:09 AM
