Thread: is it safe too......................
Results 1 to 11 of 11
  1. #1 is it safe too......................
    SE Level Member GTPAIELLO's Avatar
    Aug 2012
    weymouth, ma
    he everyone how are you? Just a quick question for you guys , I was just wondering is it safe to flash my PCM back to stock and then re-do a tune and install it ? thanks for your help !
  2. #2 Re: is it safe too......................
    Yes, you can take the stock file and do a "write calibration only" to the car. Then you can continue tuning from there.
  3. #3 Re: is it safe too......................
    Aug 2012
    weymouth, ma
    and when i reflash pcm to stock do i need to drive it before i change the tune and re flash new tune?
  4. #4 Re: is it safe too......................
    Aug 2012
    weymouth, ma
    ok cool, when do u actually us the "write entire" . im new to the tuning world and i am kinda lost lol
  5. #5 Re: is it safe too......................
    You never need to do "write entire".
    And yes you can flash it back to stock then change stuff and flash it agian before you ever start or drive the car.
    Flashing it back to stock is not needed if you just want to flash it to whatever file you want.
  6. #6 Re: is it safe too......................
    Aug 2012
    weymouth, ma
    ok cool , i was trying to set up my maf hz and when scanning i was looking at the gauges to watch my KR and the indicator For the LT B1 was all red , have no clue why that happened
  7. #7 Re: is it safe too......................
    It may have been red if the numbers where at +16.4, saying you have a vacuum leak.
  8. #8 Re: is it safe too......................
    Aug 2012
    weymouth, ma
    -15 to -22
  9. #9 Re: is it safe too......................
    It might be the 60lb injectors you mention in your other thread that you didn't account for.....just an idea. wink wink.
    Pull up a stock bin file in editor, add in the injectors then save that file as #1 or anything that denotes it's your beginning point. Flash that to the pcm. Then start your tuning for the ported TB, ported SC and ported LIM. That'll all be basically covered when you tune the maf.
  10. #10 Re: is it safe too......................
    Aug 2012
    weymouth, ma
    thanks again bill for your much needed help lol , is there a thread on adding injectors tables to my stock tune ?
    2000 GTP - TURBO SETUP .
  11. #11 Re: is it safe too......................
    I'd follow the instructions I gave you in the other thread.
    Find Matt5112's post about injectors and voltage offsets etc. It was a link to all the cool kid data. Then you merely type that into the voltage offset area and change the injector flow in that table.
  1. Safe to Run 3.0 Again?
    By Hixc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 10:14 PM
  2. safe??
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2010, 01:58 AM
  3. Will this be safe?
    By Silver GTP in forum General Tech Discussion
    Last Post: 06-08-2010, 01:07 PM
  4. Is this safe?
    By Amb4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 09:48 PM
  5. Safe to run 3.2?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2009, 11:20 AM
