Thread: Fuel pump removeal on a 2002 grand prix
Results 1 to 3 of 3
  1. #1 Fuel pump removeal on a 2002 grand prix
    Nov 2012
    murrysville pa
    Hello all, I am going to replace fuel level sensor on my gt and i have some questions. The pump has a lock ring instead of a c clip. Everyone said there should be a c clip. It looks like there is not enough room to pull pump out of tank from the trunk. When i get the lock ring off, will there be enough room for the pump to be turned enough in the tank to take it out at an angle? I hope i dont have to drop tank to do this. It looks like there is not enough space to pull straight up as is will hit the trunk pan where the acess cover is. Hope this isn't a thread that is common and i could not find it. If it is i aplogize. Any suggestions before I start? Thanks
  2. #2 Re: Fuel pump removeal on a 2002 grand prix
    it will fit through the hole and come out, you need to hit the ring to turn it, (a brass punch is recommended but a screw driver works) then it will pop loose.
  3. #3 Re: Fuel pump removeal on a 2002 grand prix
    Nov 2012
    murrysville pa
    Thanks Scottydoggs....... I've removed rings before from tanks that had to be dropped. I was pleasantley suprised to find the acess door in the trunk. Maybe the pump is alot smaller in diameter than the lock ring is. If not, it looks like it will not come straight up from the tank. Got my fingers crosees. Thanks again.
  1. 1997 Grand Prix GT fuel pump help needed
    By kaylas97gp in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2015, 07:31 PM
  2. 2002 Grand Prix GT fuel sending unit question?
    By Der2z in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-17-2012, 11:10 AM
  3. 2002 GP SE Fuel Pump/Sender Unit Replacement ????
    By skyjockey in forum General Tech Discussion
    Last Post: 05-30-2012, 07:13 AM
  4. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  5. Grand Prix GXP Foglight Removeal???
    By extreme in forum 04+ Specifics
    Last Post: 08-11-2010, 03:33 PM
