Thread: P0403 EGR Demon - FIXED
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: P0403 EGR Demon
    Looks like Blue 32......blue 32....hike!
    http://www.grandprixforums.net/pcm-pinouts-70055.html
    that's if you are a 98-03...lol looks like ya might be an 06
  2. #22 Re: P0403 EGR Demon
    Pennsylvania
    One of the only two reds on the... black connector?
  3. #23 Re: P0403 EGR Demon
    Pennsylvania
    Okay, so I can test wire continuity using...uh... ohms. Which should figure out which wire I'm playing with. Right?
    Edit: Okay, so either ohms is wrong, or the wire is disrupted somewhere.
  4. #24 Re: P0403 EGR Demon
    black connector would confirm that you must be an 06.. darnit. yeah Ohms would confirm it. If you get zippo and there's only 2 red wires in the three connectors..then you have a short, which then means I'd test for the voltage that should be on that red wire. Was it +5V or +12V? Likely 5 coming off the pcm. Find which wire has it.. then in the fsm find the circuit number. That'll make it easy to ensure you have the right wire.
  5. #25 Re: P0403 EGR Demon
    Pennsylvania
    Ahaaaahhhh! I knew I wasn't crazy!
    Muhfcker apparently rubbed himself apart inside the loom by the front valve cover. That's why I couldn't get continuity from the PCM. Jiggle it and continuity came back. Let it go, and it went away. How does this happen to a protected wire?! Patching her up now.
  6. #26 Re: P0403 EGR Demon
    You should have been taught in school...that sometimes it doesn't matter how much protection you use.....thing can happen.
  7. #27 Re: P0403 EGR Demon
    Pennsylvania
  8. #28 Re: P0403 EGR Demon
    Pennsylvania
    AAAAggggghhhhhh. And the short seems to have ruined the EGR. F*ck me running. Lucky I've got a spare. What are the chances?
  9. #29 Re: P0403 EGR Demon - FIXED
    dunno...I've never had a shorted egr before. All the EGRs I've seen have been regular length...
  10. #30 Re: P0403 EGR Demon - FIXED
    Pennsylvania
  1. Wiring question for demon eyes and led strips
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 03-19-2011, 10:47 PM
  2. P0403 -- Help
    By mckillin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 05:13 AM
  3. Screamin' Demon coil packs?
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2010, 08:09 PM
  4. codes p0243 p0403 p0405 p0742 and p0010
    By IrishNation24 in forum General Tech Discussion
    Last Post: 06-11-2010, 05:13 PM
