Thread: codes p0243 p0403 p0405 p0742 and p0010
Results 1 to 20 of 26
  1. #1 codes p0243 p0403 p0405 p0742 and p0010
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    alright, heres the deal. car had been running wierd the last day or two, today i noticed it shifting a little harder then normal, more jerky, and sometimes it would shift down when it didnt need to, and drop below 1500 rpms goin like 35. never did that before, hasnt had rough idle or anything, seemed to run fine until the last drive i was on where i got all these codes on the way back home, where it really started running odd, almost seemed like tranny was ****ting itself. these are the codes
    p0243, p0403, p0405, p0742, and p0010(the 0010 code only displayed the second time i scanned DTCs, not the first, then went away after the second time and didnt come back, i scanned it like ten times after that, driving, and parked in the garage)
    i looked it up, and this is what i found out for the codes
    p0010 - "A" Camshaft Position Actuator Circuit (Bank 1)
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0403 - Exhaust Gas Recirculation Circuit Malfunction
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0742 Torque Converter Clutch Circuit Stock On
    so again p0010 went away, for now i guess. it was shifting all wierd, i heard a grinding type noise when it shifted down when i pulled into my apartment complex, and i am getting a **** ton of part throttle kr to, example, gave it a tiny bit of gas to get around a guy goin like 40, it jumped up to 3.5. gettin on the highway, at maybe 1/3 throttle, it went all the way up to 5.9, then went away when it got close to shifting.. so i have NO CLUE whats goin on..
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  2. #2 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    Thats on the Overkill PCM correct??
    You might try contacting Will to see if he has any idea's, since he's the one who tuned it..
  3. #3 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    too bad i dont have 3 months to hear back from him.
  4. #4 Re: codes p0243 p0403 p0405 p0742 and p0010
    LOL, truth...
  5. #5 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    looks like i might need reptile to do another thing for me lol...
  6. #6 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    Yeah, he's taken awhile to respond to me, but he stays busy too...you might send him an email telling him whats up, and try to have him send you a .bin file...
  7. #7 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    what do i need a bin file for?
    and last time i sent him an email, he ignored it.
  8. #8 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    if you have someone who can rewrite the PCM, you could use that file, and see if it cures it.
    And he hasn't ignored it...he's just taking his time XD.
    Was there any difference immediately after the rocker install??
  9. #9 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    difference as in all these codes and trouble? not that i noticed, until yesterday
  10. #10 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    K, Just in my experience whenever you change something, you typically have the problems right away....
    The only thing I can really think of is either there's something F***ed up in the PCM, or somewhere the wiring harness is torn up/burned. I know when I did my header install, I accidentally left the coolant temp sensor wire hang on the headers, and it burned it to all hell, and threw a few codes.
    I'd go and check your wiring harness really quick, since it's pretty simple to do.
  11. #11 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    nothin is on the headers. the are 100% clear. and i went out to check fuses rescanned with just a code reader NOT the aerforce, and it only displayed p0742
  12. #12 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    Hmmm....Can you reset the codes with the code reader, and reset the PCM? Then start the car and see if you pull any codes after that....
  13. #13 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    i did that. cleared em, started it, shifted thru gears. nothing. BUT, i just realize. last week i had unplugged the egr with the car on, it probably set those two and just didnt turn the light on, and i had also capped of the bbv at one point, so thats probably the 0243. as far as why it flashed 0010, i dont know, and that still doesnt explain why im gettin a **** ton of part throttle kr, when i wasnt before
  14. #14 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    Do you have a way to monitor a/f ratio??? You might be running lean at part throttle, causing the KR...
  15. #15 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    no i dont..
  16. #16 Re: codes p0243 p0403 p0405 p0742 and p0010
    Florida
    hmmm.....It may be that since the rocker install keeps the valves open longer, and it's not tuned, you could possibly be running lean....but I don't really see it causing that much knock at partial throttle....
  17. #17 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    yeah. anyway, this is ****ed. i need a tcc replacment. everyone says i might as well replace the trans cuz its ****ed. GOD DAM IT I DONT HAVE 2 GRAND!!
  18. #18 Re: codes p0243 p0403 p0405 p0742 and p0010
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Quote Originally Posted by IrishNation24 View Post
    What about replacing the solenoid itself? You do a shift kit? While I haven't been in one of these transmissions before, it's probably on the valvebody. Could be a fix it in your driveway sort of thing.
    And did you get a bad tank of gas perhaps? That would cause a bunch of KR.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  19. #19 Re: codes p0243 p0403 p0405 p0742 and p0010
    Banned - Busted For Scamming
    Feb 2009
    Ill do it for 1k lol
  20. #20 Re: codes p0243 p0403 p0405 p0742 and p0010
    San Diego, CA
    i have some techron in the gas right now,
    i took it to aamco, probably will be replacing the solenoind and that pressure valve or whatever, and maybe the converter itself. hopefully just the solenoind tho. my weekend depends on TODAY dammit. they better get this done.
  1. p0243 code
    By IllegalIntentions in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 08:31 PM
  2. P0243 boost solenoid
    By IllegalIntentions in forum General Tech Discussion
    Last Post: 05-09-2010, 12:54 AM
  3. p0742 code
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-21-2010, 05:24 PM
  4. P0243 and an intense shift pac????
    By Tony in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2010, 04:04 PM
  5. code p0742
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-25-2009, 02:16 AM
