Hi all. I've gotten a lot of good info from this forum, but I'm looking for some confirmation or opinions on this one.
I've been noticing that my car was starting slower for a few weeks. Then about two weeks ago, just as I said to my wife "we're going to have to get a new battery soon" the "service charging system" warning showed up on the DIC. Oddly, it went away about 3 seconds after it showed up and didn't leave any stored codes. Since it was a Delco battery, I assume it was the original and bought a battery. I bought the right group size, but the negative top post was too far back. No big deal, as I just bought a side post adapter that just screws in. At the same time, I removed and cleaned the body ground. It was covered in a copper grease like anti-seize. I sanded down the body, and cleaned the connection and screw. After all that, I started the car a few times and drove it. All was well. I hooked the charger up to it to trickle charge overnight and make sure the battery was topped off.
Now for the problem. I didn't notice this right away until it started to get darker in the morning. Right after start up, the interior and head lights have a flicker. Oddly, the dash lights look fine. It just might be too dim to see it though. The flicker isn't tied to engine RPM, and goes away within a few minutes as the engine warms up. My assumption is the alternator, but it tests fine at Advance. I double checked my body and battery ground and it looks good. I've got about 133K miles, so I wouldn't be surprised if it isn't something like the rectifier in the alternator going out. I just can't help but think I made a lot of changes all at once. I wonder if the battery is bad, or if the topping off the battery did something. The car starts nice and strong, so the new battery fixed that.
I'd also like to add that the grounding system on this car is kind of pathetic. I found only two ground points, the body and the transmission. If it's grounded anywhere else, please let me know so I can check it.
Related question: How long does the transmission take to re-learn? I had some slipping before I did all this, but it got way worse after the car sat a night without the battery. It's been easily a week now and it's still slipping more than before.
