Thread: M90 supercharger needle bearings
Results 1 to 9 of 9
  1. #1 M90 supercharger needle bearings
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    I recently tore down my L67 for a reseal and to freshen everything up in general along with doing some mods along the way. One thing I did was port my blower and make a block off plate for the silencers, then JB welded it into place. After cleaning all the aluminum powder out of the case I realized I had also cleaned away most all of the grease on the needle bearings. What kind of grease is used on these? I have done some searching and have been unable to come up with anything. Thanks for any input!
  2. #2 Re: M90 supercharger needle bearings
    I just put wheel bearing grease in there.
  3. #3 Re: M90 supercharger needle bearings
    The Boss Iceman6669's Avatar
    Jun 2011
    I used ZZPs needle bearing grease
    2011 F-150 Yote powered
    There is a proper grease which you can get from zzp or intense.
  5. #5 Re: M90 supercharger needle bearings
    Oct 2012
    West Branch, MI
    I checked earlier at ZZP and they are sold out, plus do not list specs on what oil it is, they just state it is the same GM uses... Guess I will be checking intense, or maybe just ask the deal when I go to get supercharger oil later this week.
    Thanks everybody
  6. #6 Re: M90 supercharger needle bearings
    Jun 2011
    Sometimes ZZP has the item in stock they just dont get around to updating their website.. I see that all the time. I live close enough I just go by and ask. You should call them.. And ask if they have any in stock..
  7. #7 Re: M90 supercharger needle bearings
    Are we talking about grease or oil?
    Because the dealer won't stock the grease.
    Its another Nye Lubricants product. Only really available in larger quantities.
  8. #8 Re: M90 supercharger needle bearings
    Jul 2012
    Grand rapids
    super blue that is what I used but maybe hard to find
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I used synthetic high temp grease on my GEN V. It has worked well.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  1. Needle Bearings for GENV
    By foursixer in forum General Tech Discussion
    Last Post: 05-09-2012, 09:10 AM
  2. Replacing Needle Bearings
    By gtpeddie in forum General Grand Prix Discussion
    Last Post: 05-07-2012, 08:28 AM
  3. Supercharger bearings shot!:o no more supercharger?
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2011, 02:27 PM
  4. Needle Bearings falling out of Driver Trans Axle
    By justlookin in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2010, 07:44 AM
