Thread: 97 GP - Interior Blower Stays On When Car Is Off
Results 1 to 2 of 2
  1. #1 97 GP - Interior Blower Stays On When Car Is Off
    Oct 2012
    Nebraska
    I have a 97 Grand Prix and the interior fans stay on even when the engine is turned off, and when the car is on and the fans are set to off, they will also run on high. Obviously this kills the battery if I let it run all night, so I've had to remove the HVAC HI fuse to prevent it. It's starting to get cold again, and I'd really like to be able to use my heater this winter, does anyone know what might be causing this and what needs to be done to fix it? I'd appreciate any help I could get.
    Thanks.
  2. #2 Re: 97 GP - Interior Blower Stays On When Car Is Off
    Oct 2012
    Nebraska
    An update: I took it to a mechanic and they said that it might be some electronic controller (a dealer only part they said), and would cost me $400 to fix. I also looked into it more online and found people with similar problems that said it was the ignition wiring harness that needed replaced, which my brother said he could replace for around $75.
    I don't want to have the mechanic do what they said if I'm not positive it will get fixed, because then I would be out $400, and I want to avoid spending more than I have to so I'd rather not have to try both fixes. Has anyone come across this problem before or know what the most likely fix is? I just want to be done with this problem.
  1. ABS / TCS stays off
    By xDetroitMetalx in forum General Tech Discussion
    Last Post: 12-01-2010, 09:11 PM
  2. ABS Light stays on
    By 2000 Pontiac GTP SC in forum Brakes/Suspension/Chassis
    Last Post: 10-04-2010, 10:57 AM
  3. OEM Radio stays on
    By hourang in forum General Tech Discussion
    Last Post: 02-24-2010, 10:29 AM
  4. Interior Fan Stays On
    By nemscocamo in forum General Tech Discussion
    Last Post: 04-19-2009, 12:06 PM
  5. Stays in first!
    By silvermistGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-26-2008, 02:42 PM
