Thread: remote start on 08 GP base not working
Results 1 to 20 of 23
  1. #1 remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    I have a 2008 Base GP, it came with remote start, which has worked perfectly until this past month after the dealer replaced my power steering pump, after that it's a piece of #$%#...
    When I do the lock then remote start and hold it in until the starter starts it sounds like its fine then after the starter turns its like the starter gives up after a second of trying and you hear the engine fizzle out... try again same thing... get in the car and do hte ignition key turn starts with no problems
    I have absolutly no problems with the key in the ignition starting... I assumed they used the same system to start the car just one is triggered wirelessly...
    why would remote start fail when key turn works perfectly? or did my dealer screw something up?!... or do I need to repair the key-fob or something?
  2. #2 Re: remote start on 08 GP base not working
    SWPA
    Is your check engine light on?
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    I think a check engine light disables it all together I dont think it would still try to crank
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: remote start on 08 GP base not working
    SWPA
    He could be confusing the relay sound with thinking the starter is doing something. It makes weird noises like its going to "try" to start it, but then doesn't.
  5. #5 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    when the remot start fails you you get the noise like the engine is still spinning and dieing then a noise like you get when you put a playing card in bike spokes for a second... after that if you start if from inside you can tell the last start had trouble because it takes twice as long to crank the engine before it catches in the run state
  6. #6 Re: remote start on 08 GP base not working
    SWPA
    Quote Originally Posted by bluebsh View Post
    If you are getting a sound like that the bendix might not be engaging the flexplate.
  7. #7 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    but only when its a remote start?... that's what has me lost, I have never had a problem with a direct key in the ignition start, it starts instantly that way..
  8. #8 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    they do go through the same system though right? the key ignition just sends a "start engine" signal to the starter controller. like it does with remote start, none of the old hold the key to start stuff, just turn let go and its started... the dealer wants to replace the starter, but I highly doubt its the starter as it works fine inside the car
  9. #9 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    Check engine light does not come on, there is no ODBC-ii codes, this is not a relay, it is the same exact sound you get when you turn the key, it is cranking and then it cuts out before the engine starts but only when you use remote start... do it from the inside ignition key and it works perfectly
  10. #10 Re: remote start on 08 GP base not working
    SWPA
    Could be poor connection with the circuit board, could be low battery in the FOB.
  11. #11 Re: remote start on 08 GP base not working
    SWPA
    Could be a slightly weak ground? I wonder if it takes more power for the remote start to activate.
    I've noticed with my own factory remote start that sometimes it seems to have to crank more to start than just using the key.
  12. #12 Re: remote start on 08 GP base not working
    GT Level Member GMCustomerService's Avatar
    Michigan
    bluebsh,
    The remote vehicle start feature will not operate if any
    of the follow occur:
    - The remote start system is disabled through the DIC.
    - The vehicle’s key is in the ignition.
    - A door on the vehicle is open.
    - The vehicle’s hood is open.
    - The hazard warning flashers are on.
    - There is an emission control system malfunction.
    - The engine coolant temperature is too high.
    - The oil pressure is low.
    - Two remote vehicle starts, or one start with a time extension, have already been provided for that ignition cycle.
    Are any of these a possibility?
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  13. #13 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    * Nope it's enabled
    * Doing this from outside the car while the car is locked
    * All doors are closed
    * Trunk and hood are closed and locked
    * Not on
    * This one i'm not sure about, I have an ODBC-II scanner that shows emission status, when I plug it in, the emission status can be red, yellow or green, it's always yellow like something is wrong, but I can never find any info in it that says why it's yellow... I plugged the same device into an 06 Buick La Cross and get green for the same indicator... how do I go about finding out why it thinks there might be an emissions issue? any codes to look up or values to look at in the ODBC-II system?
    * Temp is normal, this only seems to happen on a cold start when the engine hasn't ran for 12 hours or more
    * Pressure appears to be fine
    * This is happening on the first attempt, if I try it again it will still fail then show on the DIC "Remote start disabled" after doing a key ignition that goes away and its reenabled according to the DIC and works again
  14. #14 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    could a bad relay cause this? I did a remote start from inside the car I heard a relay click the engine try to start a click again and it died...
    started it then with a key and no relay clicking noise, just straight started up
  15. #15 Re: remote start on 08 GP base not working
    Michigan
    bluebsh,
    I would suggest taking the vehicle back to the dealer that did the repairs and explain the issue you are experiencing.
    Please keep us posted.
    Louis
    GM Customer Service
  16. #16 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    The dealer just replaced the starter and said it was "bad" I knew that wasn't the issue, the starter works fine with the key directly, and works with remote start, the engine just dies on remote start almost like somehow you did the remote start and pressed the start button again right after the engine started to cancel it...
    they wouldn't look at anything else until the starter was changed... which of course costs me money... I've never had the GM dealer fix a problem on the first try and that always makes me mad because I tell them it's definatly not something then they come back and say lets try that first have a $100 deductable on my extended warrenty so the more they "try" the more I have to pay ugh
    edit:
    starting to think it is the key fob.... took the fob apart and shorted the buttons manually and the car started up fine
  17. #17 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    well I figured it out myself with no help of the dealer who wanted to yet replace another part...
    noticed the other night when I turned my steering wheel the headlights dimmed... which is odd... that's either an alternator problem or a battery problem... first thing I looked at was the battery, pulled open the positive terminal cover and holy cow was it coverd in corosion... sprayed some battery cleaner on it with an acid indicator... turned pink immediatly on a good bit of the battery top.. cleaned that all up wire brushed it washed it off with water, did the batery cleaner again still pink... kept doing it until it stoped turning pink, put it back together and bingo remote start works instantly again no hesitation on start at all......
    why in the world didn't the dealer look at this first
  18. #18 Re: remote start on 08 GP base not working
    Kansas
    I had the same problem with mine. You can hear it turning the engine over then just stop. It did however actually start up one day out of the blue when I tried it. But Louis answered my problem.
    Something about no cat and no EGR rings a bell here.
    Sidethought: My personal opinion but remote start is a joke. Having a car idling running pig rich from being cold. Burn through gas like no other when I could actually be moving down the road while increasing engine temperature faster. Man up and deal with the climate, we can accommodate ourselves for things like that.
  19. #19 Re: remote start on 08 GP base not working
    SWPA
    Quote Originally Posted by NegativeOne13 View Post
    I disagree. Sure it's running a little rich from a cold start, but its not using more fuel than actually driving for 8 minutes. And on mornings when there is thick ice on the windows you need the defrost to help clear them so you can even see to drive.
  20. #20 Re: remote start on 08 GP base not working
    Nov 2011
    Indiana, PA
    yeah, that's what I use it for mainly to start the car inside heating up to losen frost and ice.. it can do that while I am getting ready in the morning to go to work makes cleaning the windows a heck of a lot easier
  1. 07 GP remote start not working and is turning the alarm on
    By benny722 in forum Audio, Security & Visual Electronics
    Last Post: 05-04-2012, 11:17 PM
  2. adding remote start to a 2006 base GP
    By silvervipertb in forum 04+ Specifics
    Last Post: 04-04-2012, 07:37 AM
  3. Factory Remote Stopped Working
    By mltyplx in forum Audio, Security & Visual Electronics
    Last Post: 12-20-2010, 09:22 PM
  4. Remote Start
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2009, 01:00 PM
