Thread: 07 GP remote start not working and is turning the alarm on
Results 1 to 16 of 16
benny722 07 GP remote start not... 04-02-2012, 09:59 AM
DreadMcLaren Re: 07 GP remote start not... 04-02-2012, 10:02 AM
benny722 Re: 07 GP remote start not... 04-02-2012, 10:37 AM
DreadMcLaren Re: 07 GP remote start not... 04-02-2012, 10:38 AM
NegativeOne13 Re: 07 GP remote start not... 04-02-2012, 10:38 AM
DreadMcLaren Re: 07 GP remote start not... 04-02-2012, 10:45 AM
benny722 Re: 07 GP remote start not... 04-02-2012, 10:47 AM
infinite_one You need new rubber on your... 04-02-2012, 10:48 AM
DreadMcLaren Re: 07 GP remote start not... 04-02-2012, 10:48 AM
benny722 Re: 07 GP remote start not... 04-02-2012, 10:52 AM
infinite_one Just buy the rubber inserts.... 04-02-2012, 02:12 PM
michaelbm Re: 07 GP remote start not... 04-03-2012, 07:03 AM
infinite_one It's not the damn remote! Buy... 04-03-2012, 11:10 AM
infinite_one Seriously! I could always use... 04-03-2012, 01:00 PM
Korben Re: 07 GP remote start not... 04-04-2012, 10:47 AM
infinite_one So op how well did replacing... 05-04-2012, 11:17 PM
  1. #1 07 GP remote start not working and is turning the alarm on
    SE Level Member benny722's Avatar
    Apr 2012
    South Florida
    i have a problem with this i dont understand why i just bought the car like that and would like to figure out if anyone else has had that problem
  2. #2 Re: 07 GP remote start not working and is turning the alarm on
    St. Cloud, MN
    Make sure its turned on in the DIC.
  3. #3 Re: 07 GP remote start not working and is turning the alarm on
    Apr 2012
    South Florida
    what do you mean the DIC?
  4. #4 Re: 07 GP remote start not working and is turning the alarm on
    St. Cloud, MN
    Driver Information Center.
  5. #5 Re: 07 GP remote start not working and is turning the alarm on
    Kansas
    Driver Instrument Cluster.
    The buttons and screen in the middle of the dash that displays mileage, date, and so on. There is an option to disable remote start via the DIC.
  6. #6 Re: 07 GP remote start not working and is turning the alarm on
    St. Cloud, MN
    Driver Instrument Cluster? LOLOLOLOL wut?
  7. #7 Re: 07 GP remote start not working and is turning the alarm on
    Apr 2012
    South Florida
    i already did go into there and turn it on but i still am having the same problem
    SE Level Member infinite_one's Avatar
    Jul 2011
    detroit
    You need new rubber on your keyless its worn out
    Sent from my iPhone
  9. #9 Re: 07 GP remote start not working and is turning the alarm on
    St. Cloud, MN
    Buy it from a dealer? If so, bring it back and let them know about the issue and have them fix it.
  10. #10 Re: 07 GP remote start not working and is turning the alarm on
    Apr 2012
    South Florida
    alright ill try that but do you know if its possible to program the remote if i get a new on without going to the dealer
    Jul 2011
    detroit
    Just buy the rubber inserts. It's all you will need. No need to reprogram
    Sent from my iPhone
  12. #12 Re: 07 GP remote start not working and is turning the alarm on
    New Brunswick
    Since it it's setting off the alarm when your trying to use the remote I suspect its the remote boards itself.
    Try holding the lock button, then while still holding the lock button push and hold the panic button and see if it starts for you.
    Had a few do this and it has always been the remote at fault everytime so far with these things.
    Jul 2011
    detroit
    It's not the damn remote! Buy the rubbers if they don't work send em to me for a full refund!
    Sent from my iPhone
    Jul 2011
    detroit
    Seriously! I could always use a spare!
    Sent from my iPhone
  15. #15 Re: 07 GP remote start not working and is turning the alarm on
    Apr 2012
    USA
    I had a similar issue in my 2001 Grand Prix GT, and for a very odd reason. The key fob was only occasionally unlocking the door. Turning the car on would set off the alarm. Turns out my battery was the culprit, it had been the victim of serious corrosion. Unhooked it and cleaned the corrosion off, used a battery tester and it was only putting out about half the CCA I needed. For some reason, this was triggering the alarm. New battery fixed the problem entirely. When's the last time you replaced your battery?
    Jul 2011
    detroit
    So op how well did replacing just the rubber work for you?
    A 2001 remote is a completely different design than an 07.
    Sent from my iPhone, please disregard grammatical errors.
  1. Remote start activating car alarm.
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 12-23-2011, 12:06 AM
  2. New Alarm/remote start system
    By bcracing in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2011, 06:20 AM
  3. car alarm/remote start
    By putskijr in forum Audio, Security & Visual Electronics
    Last Post: 11-16-2010, 03:36 PM
  4. how hard is it to install an alarm with remote start
    By nascartech in forum Audio, Security & Visual Electronics
    Last Post: 11-01-2010, 05:55 PM
