Thread: Gt radiator fit GTP?
Results 1 to 16 of 16
  1. #1 Re: Gt radiator fit GTP?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    If you use the L67 motor & trans, you must use the PCM too. If you slap the L67 and keep your trans, you need to get your pcm tuned for the correct gear ratio.
    For the harness, you can just get an adapter to use the MAP of the l67 & the solenoid on the boost bypass canister. (I personally used a different 2-bar map and run it without the solenoid.)
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  2. #2 Re: Gt radiator fit GTP?
    May 2012
    United States
    Quote Originally Posted by WolvesSoulZ View Post
    ok, great! Sounds like im going to be putting my hubby to work! Lol! Thanks so much for the help!
  1. 2-row radiator from 04-08 gp
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 03:35 PM
  2. Radiator help
    By Jordan Flowers in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 09:54 PM
  3. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
