Thread: Gt radiator fit GTP?
Results 1 to 16 of 16
  1. #1 Gt radiator fit GTP?
    May 2012
    United States
    Im have a 99 gt and am buying a 99 or 98 gtp that is missing the radiator. I want to use the gtp for parts and turn my gt supercharges, but am not sure yet because my gt has several dings here and there and to use the gtp rather than the gt as a dd would be less work. My question is, will my gt radiator work on the gtp if needed? Any help is appreciated!
  2. #2 Re: Gt radiator fit GTP?
    St. Louis
    Yep, should drop right in.
  3. #3 Re: Gt radiator fit GTP?
    May 2012
    United States
    Awesome, thanks! I looked it up on autozone after I posted this and seen they have different part numbers so was thinking it wouldn't interchange.
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Don't do it. The GTP radiator is thicker. If you put the GT radiator in it you will loose cooling efficiency with the thinner radiator.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  5. #5 Re: Gt radiator fit GTP?
    May 2012
    United States
    Ahh, good to know. But if I make my gt supercharged and move over the top end and transmission can I keep my same radiator, or do I need to upgrade to a gtp radiator?
    Ohio
    You're not gonna notice ****... So then whenever somebody top swaps, they are going to have worse cooling efficiency cuz of the thinner radiator?
    BULL SH1T
  7. #7 Re: Gt radiator fit GTP?
    GT Level Member WolvesSoulZ's Avatar
    Québec
    I've got an L67 in my car with the GT radiator, no overheating issues at all. Stays cool at 180*!
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
    May 2011
    United States
    Do what you want, I'm just stating the facts and my opinion.
    Sent from my Droid
    Ohio
    Opinions are like assholes...
    May 2011
    United States
    Cool story bro.
    Sent from my Droid
  11. #11 Re: Gt radiator fit GTP?
    May 2012
    United States
    I think I'll upgrade, better safe than sorry. Especially cuz I live in AZ and its mostly hot here. iI have an entire car, making my gt supercharged after all, can any of you recommend what else I should transplant? my gt has the dic, do I need the one out of the gtp to show the boost level, or does mine already have that ability?
    May 2011
    United States
    I would swap the HD diff housing from the GTP to the GT. Or maybe the whole trans if the one in the GTP is in better condition.
    Sent from my Droid
  13. #13 Re: Gt radiator fit GTP?
    Québec
    Your DIC already has this ability, the boost gauge will light up once you plug in a 2-bar map sensor, with the right pcm and all.
  14. #14 Re: Gt radiator fit GTP?
    May 2012
    United States
    Quote Originally Posted by WolvesSoulZ View Post
    So, would I need to swap out the pcm and wiring harness? I would like to use as much from this donor car as possible. Minus the radiator, and mass airflow sensor, this car is complete!
    BTW, will have tons of parts when I am done hacking away what I want.
  15. #15 Re: Gt radiator fit GTP?
    Québec
    If you use the L67 motor & trans, you must use the PCM too. If you slap the L67 and keep your trans, you need to get your pcm tuned for the correct gear ratio.
    For the harness, you can just get an adapter to use the MAP of the l67 & the solenoid on the boost bypass canister. (I personally used a different 2-bar map and run it without the solenoid.)
  16. #16 Re: Gt radiator fit GTP?
    May 2012
    United States
    ok, great! Sounds like im going to be putting my hubby to work! Lol! Thanks so much for the help!
  1. 2-row radiator from 04-08 gp
    By TEK310 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-22-2012, 03:35 PM
  2. Radiator help
    By Jordan Flowers in forum General Grand Prix Discussion
    Last Post: 06-22-2012, 09:54 PM
  3. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
