Thread: fueling issue
Results 1 to 8 of 8
  1. #1 fueling issue
    Oct 2012
    portland OR
    My 98 gtp wont fill up all the way with gas It did a couple time but it usually shorts it a gallon and a half or so not sure why.
  2. #2 Re: fueling issue
    St. Louis
    Check the evap canister and purge valve. Might be bad causing the vapors to trip the pump early.
  3. #3 Re: fueling issue
    Oct 2012
    portland OR
    yea could be. i have had more problems with this gm than i have my mustang in the 2 years i had that. yea the grand prix is faster but its a money pit so far
  4. #4 Re: fueling issue
    St. Louis
    Well, being a 98 any car this age is going to have issues. Granted some are more prone to certain things than others, but in the end they all wear out. Give the purge valve or canister a quick search and see if anything comes up as it's pretty common. If nothing matches quite what you're looking for then post it up and we can help.
  5. #5 Re: fueling issue
    Oct 2012
    portland OR
    ok thanks
  6. #6 Re: fueling issue
    How do you know...it's not allowing you to fill the last gallon or two?
    Hopefully you aren't going off the basis of tank empty on gauge meaning the tank is actually empty. That's not so.. GM hedged the empty mark by a good 2-5 gallons. A quarter of the fuel tank on the gauge isn't a quarter of what the capacity really is.
  7. #7 Re: fueling issue
    Oct 2012
    portland OR
    yea it will go 70 miles or so ona 1/4 tank gas i meant theres a needle at the top and it would go to a notch or two below that instead of all the way full. and they would try to put more in it but it wouldnt take it. last time it filled up all the way no problem so idk
  8. #8 Re: fueling issue
    Could be the gauge is messed up. That happens sometimes.
  1. Question about my fueling
    By shawnschuldt in forum PCM Tuning
    Last Post: 08-18-2012, 05:02 PM
  2. Fueling issue?
    By dmahlikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2012, 12:57 PM
  3. Fueling
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-11-2011, 08:22 AM
  4. over fueling?
    By savannaz34 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 02:23 AM
  5. '04 GP GT - 2 Questions, Fueling and start up related.
    By Ryan04GPGT in forum General Tech Discussion
    Last Post: 03-19-2009, 04:16 PM
