Thread: Low Beam issue
Results 1 to 4 of 4
  1. #1 Low Beam issue
    Oct 2012
    Hello Everyone!
    I'm having an issue with my car and am looking for a little assistance! my passenger side low beam is not working. the low beam works on the drivers side but not the passenger side. The high beams work on both lights. I replaced the bulb with brand new ones but am still having issues. I checked the fuse for the headlights and it checked good. Is there a separate fuse for each low beam? what should i check next? I have a 98 GTP
    Thank You for your help,
    Steve
  2. #2 Re: Low Beam issue
    Oct 2012
    So i swapped the driver side and passenger side assemblies and it worked. It is in my headlight assembly. If it possible to remake the connectors for the headlights? or will i have to buy a while wiring harness?
  3. #3 Re: Low Beam issue
    check for any corrosion on the contacts in the socket. and a bit of di electrical grease can help too.
    if the socket is clean test for power. you can do this with a 2 dollar 12 volt test light.
    also check the wires to the socket, a broken or cracked wire can make it fail to work as well.
  4. #4 Re: Low Beam issue
    Nov 2008
    Central NJ
    I had a problem like this on my 99 GTP and I was cursing it for a while because everytime I went to touch the light to fix it, it would come back on again it would work for a while until it decided to die again. It ended up being a nick in the wire about 1 foot back from the headlight connector. The nick ended up corroding to the point of on a spot of rust making the connection. After fixing the wire, no more problems.
  1. Low Beam Issue
    By Andrew Nelson in forum General Grand Prix Discussion
    Last Post: 06-02-2012, 12:19 PM
  2. Hi and Low beam together mod?
    By codysGS in forum Buick Regal
    Last Post: 02-09-2011, 01:26 PM
  3. Halo hi beam issue
    By robstout in forum Visual/Body Modifications
    Last Post: 04-21-2010, 09:23 PM
  4. Need High Beam, Low Beam, Fog wiring help...
    By TuKoolGTP in forum General Tech Discussion
    Last Post: 12-29-2009, 12:57 PM
  5. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
