Thread: Ignition Fuse Keeps Blowing
Results 1 to 4 of 4
  1. #1 Ignition Fuse Keeps Blowing
    SE Level Member overdose666's Avatar
    Oct 2011
    Houston, TX
    My room mate has a 1997 GTP, for the past week of so he's been having problems with it. The ignition fuse keeps blowing, causing the car to die and the only way we're able to get it into neutral to push it is to put a temporary jumper on the fuse. Before I start tearing into this thing to find a short I was wondering if anyone had some helpful info. Where is the most likely place for it to be shorting out, or are there any other parts that could be faulty and causing the fuse to blow.
  2. #2 Re: Ignition Fuse Keeps Blowing
    Oct 2011
    Houston, TX
    Got some more info, its fuse No. 5 under the hood, ignition main 1. Followed all wires from the ignition on the column to the firewall and didnt see any problems, than followed back from the fuse box to the fire wall and didnt see anything, now I'm completely lost...
  3. #3 Re: Ignition Fuse Keeps Blowing
    Ignition switch bad?
  4. #4 Re: Ignition Fuse Keeps Blowing
    Oct 2011
    Houston, TX
    Got more info for you guys.
    The problem started out of no where according to the owner, coming home from work and the car randomly died. The next day he went to go get it and found out the main ignition 1 fuse had blown, replaced it, made it about a block down the road and it blew again. Then he was a dumbass and used a welding rod to bypass the fuse, that got him a good 30 miles till it melted through.
    I've got the whole dash taken out and ive found a few crispy wires from some problems he had with his cigarette lighter a year ago, but i cant find anything exposed. I've gone from the ignition on the column to the firewall, from the under hood fuse box to the firewall, and from the ECM to the fuse box and firewall.
    Dont see any shorts, whats the first part i should try replacing?
  1. Blowing MAF fuse in an 01 3.1
    By NSGRAND in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-10-2012, 06:32 PM
  2. Why do i keep blowing this fuse?
    By GTLGDP in forum General Tech Discussion
    Last Post: 11-04-2011, 09:01 PM
  3. keep blowing fuse for fog lights.
    By RyanL in forum Audio, Security & Visual Electronics
    Last Post: 10-30-2011, 01:58 PM
  4. Help with blowing reverse fuse
    By ck115 in forum General Tech Discussion
    Last Post: 08-02-2010, 09:05 PM
  5. MAF Fuse Blowing
    By shoboy07 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2009, 07:05 PM
