Thread: valve cover gaskets
Results 1 to 7 of 7
  1. #1 valve cover gaskets
    SE Level Member Garrett Mofford's Avatar
    Oct 2012
    Cincinnati
    so im doing my valve cover gaskets in the next few days.. any tips or heads up to speed up the job or to watch out for..
    jus so we understand lol this is the first vc job im gonna do by myself.. id rather it be only me working under the hood
  2. #2 Re: valve cover gaskets
    New gasket and grommets and away you go.
    Its pretty straight forward, take your time, clean it up good and you'll be fine.
  3. #3 Re: valve cover gaskets
    Oct 2012
    Cincinnati
    removed*
  4. #4 Re: valve cover gaskets
    Oct 2012
    Cincinnati
    for the rear, does the alternator have to be remvoed?
  5. #5 Re: valve cover gaskets
    Yes it does. And if you own a supercharged car, the MAP/bracket and EVAP thing will come off aswell.
    Its only a few more steps but nothing hard.
  6. #6 Re: valve cover gaskets
    It would help if we knew what year and motor you have.
  7. #7 Re: valve cover gaskets
    97 and 98 don't need the alt bracket removed because racekar.
  1. 04 gtp Valve cover gaskets???
    By justin98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-03-2010, 03:14 PM
  2. Valve cover gaskets
    By Joe m in forum General Tech Discussion
    Last Post: 11-23-2009, 08:50 PM
  3. Valve cover gaskets...
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2009, 06:14 PM
  4. Valve Cover Gaskets
    By fragrep in forum General Tech Discussion
    Last Post: 03-11-2009, 07:46 PM
  5. Valve cover gaskets
    By spenc938 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-05-2008, 07:34 PM
