Thread: 06 Grand Prix problems
Results 1 to 12 of 12
  1. #1 06 Grand Prix problems
    Oct 2012
    missouri
    I have an 06 grand prix that is showing these codes: P1125, P2125 and P2138 and has the reduced engine power light as well as the engine light on. We have replaced the accelerator pedal however, it's still having the same problem and showing the same codes. Any ideas to try?
  2. #2 Re: 06 Grand Prix problems
    id toss a tps sensor on it. it may need to be re calibrated tho.
    P1125 - Google Search
    P2125 - Google Search
    P2138 - Google Search
  3. #3 Re: 06 Grand Prix problems
    Oct 2012
    missouri
    What is the tps sensor? And how do we recalibrate it?
  4. #4 Re: 06 Grand Prix problems
    tps= throttle position sensor. its on your throttle body.
    OBD2 - OBDII Code P1125 - Throttle position sensor intermittent | Engine-Codes.com looks like you need a scanner to calibrate it.
  5. #5 Re: 06 Grand Prix problems
    Oct 2012
    missouri
    OK, Thanks so much, I'll let him know. I'll keep you posted!
  6. #6 Re: 06 Grand Prix problems
    Oct 2012
    missouri
    We were actually told by a dealer that the car didn't have a tps....
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    It's built into the throttle body itself. Drive by wire.
    Sent from my Galaxy SIII on Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  8. #8 Re: 06 Grand Prix problems
    Oct 2012
    missouri
    OK. We have replaced the throttle body, the entire thing. Also the accelerator pedal and the same codes are still reading and the problem still exists. Any other ideas?
  9. #9 Re: 06 Grand Prix problems
    Yoga city
    ill ask you have a cone filter? either way i would look or shake the wireing harness by pcm, i got these codes before randomly and was from my filter saggin on the wire. i think they were a yellow and green wire
  10. #10 Re: 06 Grand Prix problems
    Oct 2012
    missouri
    I know they went through all the wiring last night looking for a frayed or broken one, and found nothing, and it still won't clear the codes. Today, we are taking it to a dealership to have it diagnosed there........hopefully it's something easy for them to find!
  11. #11 Re: 06 Grand Prix problems
    GT Level Member GMCustomerService's Avatar
    Michigan
    RMACKEY,
    Please keep us posted of the results of your dealer visit. Feel free to contact me privately if you have additional questions.
    Louis
    GM Customer Service
    Check out the NEW Owner Center at: My.GM.com
  12. #12 Re: 06 Grand Prix problems
  1. 91 Grand prix with problems...
    By neorules in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-23-2011, 06:16 PM
  2. 99 grand prix gtp problems
    By schmitt in forum General Tech Discussion
    Last Post: 05-07-2011, 10:48 AM
  3. 04 grand prix GTP problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 05:45 AM
  4. Problems with a 93 Grand Prix LE..
    By thehollowaytape in forum General Tech Discussion
    Last Post: 05-14-2010, 05:37 PM
  5. 01 grand prix problems
    By ryanreilly 69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2010, 09:38 PM
