Thread: 04 grand prix GTP problems
Results 1 to 20 of 27
  1. #1 04 grand prix GTP problems
    GTP = BEAST 04PrixGTP's Avatar
    Houston
    i just got the car and the abs light,brake light, and t/c light is on sometimes they go off and every thing works fine but after like 20 miles the lights pop back on any ideas on what it can be and how do i install a boost gauge
  2. #2 Re: 04 grand prix GTP problems
    Omaha, NE
    Wheel hub bearing(s) are probably bad.
  3. #3 Re: 04 grand prix GTP problems
    Houston
    would that explain when i floor it the front end vibrates lk a biatch and how hard are they to change
  4. #4 Re: 04 grand prix GTP problems
    Kansas
    hm maybe you need a alignment done and replace the hubs if you can figure out which ones are tripping the light
    SOLD 1999 GT Silvermist TS
  5. #5 Re: 04 grand prix GTP problems
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    Front end vibration under acceleration is generally an indication of a bad half shaft but could also be a hub.
    The ABS issues sounds like an ABS sensor is having intermittent connection issues. The traction control/ Stabilitrac systems rely on the ABS sensors for information and if a wheel isn't reporting data it will disable the entire system and toss up those warning lights.
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  6. #6 Re: 04 grand prix GTP problems
    Houston
    how hard are the hubs to change ?
  7. #7 Re: 04 grand prix GTP problems
    Chicago, IL
    Nut difficult at all. You just need some large wrenches...
    We stock them too, the hubs that is.
  8. #8 Re: 04 grand prix GTP problems
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    I had that problem one of the ABS sensor wires was rubbing and when I hit a bump I lost my ABS. If it's just a bad wire you could repair that section without trashing the hub bearing if it isn't bad yet.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  9. #9 Re: 04 grand prix GTP problems
    I wouldn't buy anything other than TIMKIN bearings from Autozone. Best hub assembly for the WBody platform.
  10. #10 Re: 04 grand prix GTP problems
    let's not forget SKF
  11. #11 Re: 04 grand prix GTP problems
    Houston
    okay and i got anthor question when i floor the car when i get to about 4800 - 5000 its breakin up like its missin but when i put it in nutreal and rev it to 6 grand it dont miss at all
  12. #12 Re: 04 grand prix GTP problems
    Omaha, NE
    Sounds like a trans/ shiftpoint issue. Are you using a stock pcm and tune?
  13. #13 Re: 04 grand prix GTP problems
    Chicago, IL
    Quote Originally Posted by 04PrixGTP View Post
    There's very little actual load on the engine when it's in neutral so many ignition problems don't show up in neutral. To me that sounds like an ignition issue. I'd take a look at the plugs and wires. It could also be a lack of fuel. There's really no way to know for certain without scanning but plugs and wires are always a safe bet when you're having problems like this.
  14. #14 Re: 04 grand prix GTP problems
    Houston
    all i have done to the car is new spark plugs, msd wires ,intake and exhaust system and im on the stock pcm
  15. #15 Re: 04 grand prix GTP problems
    Chicago, IL
    Put your stock wires back on and see if that makes a difference. MSD wires are notoriously crappy.
  16. #16 Re: 04 grand prix GTP problems
    Houston
    it was doin it when i bought it and the stock wires were on before i did any mods
    My 04 Grand Prix GTP is a BEAST
  17. #17 Re: 04 grand prix GTP problems
    Check the coils then
  18. #18 Re: 04 grand prix GTP problems
    Houston
    are those msd coils any good
  19. #19 Re: 04 grand prix GTP problems
    No...I'm talking swap the coils around on your car and see if the misfire follows a certain cylinder...if so then you've got a crappy coil pack.
  20. #20 Re: 04 grand prix GTP problems
    Houston
    i know what u mean im talkin bout replacing all of them with those msd coil packs
  1. 99 Grand prix blower fan problems...
    By grandprixtokey in forum General Tech Discussion
    Last Post: 08-03-2011, 06:03 PM
  2. 84' grand prix brake problems
    By rwilhelms in forum General Tech Discussion
    Last Post: 05-18-2010, 07:42 PM
  3. Problems with a 93 Grand Prix LE..
    By thehollowaytape in forum General Tech Discussion
    Last Post: 05-14-2010, 05:37 PM
  4. 01 grand prix problems
    By ryanreilly 69 in forum General Tech Discussion
    Last Post: 02-11-2010, 01:52 AM
  5. 01 grand prix problems
    By ryanreilly 69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-10-2010, 09:38 PM
